The turbo blanket / heat shield had disintegrated in my car and I was running without one for some time...
New part from Audi (06A129597T is for 225 quattro) is about 85euros which I thought was a bit expensive so decided to try to fabricate a part myself.
First, to get the fire cloth: The material is similar to a fire blanket but one side is aluminized which is what you see outside, the other side is white and is made of glass fibre. Since no fire extinguisher shops carried cloth by the metre, I looked at ebay first:
example:
https://www.ebay.co.uk/itm/EXHAUST-HEAT ... 2180977081
But that is not good; it says 550F fire resistance (287C) which I think is not enough for a turbo that goes up to 900C
Found some material in a marine fire supplies shop, they had aluminized fabric in various thicknesses (0.3-4mm), rated at 550C (or so they told). They also had other grades (up to 1500C I think) but these cloths were dark brown, not aluminized so didnt get these. Got one square meter fabric.
Second, securing the fabric: The oem cloth is 3 pieces, top is fastened with metal clips, the bottom is sewn together which had disintegrated in mine so it was the weakest link. Decided that the bottom part should be 2-ply and secured with clips, not sewn.
OEM Clips
After using the old pieces to roughly make a pattern, cut two pieces and sew together at the bottom for a test fit. After some test fitting and fiddling with the pattern and how each piece should be attached, arrived at a sample and cut more two fire blankets for testing. Fabric is easily cut with a *decent* pair of scissors.
These cloth clips are put in place by a vice which has top and bottom removable "molds" and are pressed into place. Instead of buying the vice I found a seamstress supply shop :roll: which were able to fit them at 1eur per clip so 12 clips in total per blanket.
Engineering Sample 1 ready: The narrow part goes toward the turbo and the wide towards the charge pipe.
Then you clip the rectangle part to the clip in the back to tighten it further into place.
Fitted in the car and all is good. Now to see how long it will hold 8)
And I have enough cloth to fabricate other aluminized parts such as the cover of the coilpacks etc.
example:
OEM Clips
