I was having Pcv trouble on my mk2 TT recently which caused my ecu to make it go into limp mode. I previously had Pcv issues and replaced it with another plastic one which lasted about 9 months. I figured instead of getting another cheap plastic one I will order a Pcv delete kit with an oil catch can. Problem is I couldn’t park the car and wait for it to get here, it’s my only way of transportation so I decided to ride in limp mode for a few days. The other day I turned the car on getting ready to leave my house when for what ever reason it cut off after about a minute of idling, I tried to crank it back up and it sounded like it wanted to but just wouldn’t.
First I checked my battery voltage when trying to crank on my obd11 and it was low so I switched the battery, that was not it at all XD I got 4 engine codes being turbo/supercharger under boost which I’m sure was from my Pcv that’s now fixed. Crankshaft position-camshaft position correlation bank 1 sensor A although I am getting around 200 rpms when cranking. Cyl 3 misfire… when I pulled my plugs cyl 3 was flooded so I cleaned that up. Lastly power supply terminal 30 voltage too low, this one showed up again even after clearing codes.
I’ve been trying to trace the voltage threw my ecm relay and for some reason it’s not grounding out. I was reading up and am getting told I might want to continuity test my ground wire from that relay to my pin on the ecu harness. The more ready I do on it though I see people saying hpfp. Please Please help me out before I dig to far in the electronics when possibly I don’t even need to. So I hope
