After reading the recent post on replacing the PCV valve, I went looking for it on my V6-3.2ltr engine. Evidently there isn't one mentioned in the parts list (see diagram below). I could only find a PCV heating element (N79) but no PCV as would be found in the 1.8 or 2.0 engines.
For an alternative repair follow this link -
3.2 VR6 (BUB) PCV Diaphragm Replacement Alternative
https://www.ttforum.co.uk/forum/viewtop ... &t=1965923
The closest thing to a PCV valve in the V6-3.2ltr engine I can find is called a Crank Case Valve (CCV) diaphragm located inside the Cyclone Oil Separator (COS) which is situated inside the hump on the right side of the Cylinder Head Cover directly behind the oil cap.
Evidently the CCV is incorporated into COS which, in turn, is bolted inside the Cylinder Head Cover. Which means if the CCV diaphragm fails, there's no replacement part for it from VW/Audi and you have to replace the entire Cylinder Head Cover. Seriously!?
From what I have researched, the CCV diaphragm can be replaced as an after-market kit but it looks like a major PITA job to do it since you have to remove the Intake Manifold in order to access the Cylinder Head Cover.
YouTube CCV membrane source and replacement instructions from RKXTech -
RKX VW & Audi 3.6 & 3.2 Engine Valve Cover PCV Valve Diaphragm
