As the TT`s alternator charges at around a 14.2 volts continuously when engine is running can I replace starter battery with an AGM type.
It's the rate to which this happens that determines the battery life. Voltage and current will vary with charge/discharge but if held constant over long periods (ie driving on highway) the battery life may suffer.Hoggy said:Hi, Constant volts is not constant charge, the amps/current is not constant & will vary depending on state of battery.
The volts have to be fairly constant & higher than the battery otherwise it can't flow into the battery.
Hoggy.![]()
V6 & QS gave AGM spec'd as std because the battery is inside the car.bobclive22 said:Hoggy,
A standard alternator giving out a fixed charge of 14.1/.2 volts, is this classed as a float charge as it is I have read a high float charge that kills these batteries, does anyone on here run their MK1 with an AGM battery.
Rob.
Do those cars alternators give a constant 14.1/2 volts same as 180 & 225, I assume they are mk1`s, I see you have a 3.2 2003.V6 & QS gave AGM spec'd as std because the battery is inside the car.
It appears it has a smart alternator then, I was hoping it had a standard output one, my 180 charges at 14.1/2 continuously.imartyn
If it's any help according to the climate control readout my QS will charge at 14.3v for a few minute and then drop back to around 13.5v
How are you getting ÂŁ108 ??Gixxer123 said:Just lookong at getting a new 096 agm bosch s5 battery for the 3.2, euros do one with the discount code for ÂŁ108 which I am happy with as they are only round the corner from me.
Thanks infidel,I use agm, have done for over 4 years now, always worth it if you can afford the extra cash.
Thats the starting price, you then put the code in atbthe checkout. Comes in at 108.David C said:How are you getting ÂŁ108 ??Gixxer123 said:Just lookong at getting a new 096 agm bosch s5 battery for the 3.2, euros do one with the discount code for ÂŁ108 which I am happy with as they are only round the corner from me.
The Bosch "S5 A08" 096AGM is ÂŁ181 with the blackfriday discount. :?
I have been watching.my 3.2 is floats from 14.2 down as low as 13.3. I am trying the battery on mine first, as its only showing.11.1v.bobclive22 said:This alternator is for sale on Ebay, it is compatible with both the 180T and the 3.2 from years 1998 to 2004
AUDI TT 8N Alternator 1.8 3.2 98 to 05 Bosch 028903030 038903024G 028903028E
https://www.ebay.co.uk/itm/AUDI-TT-8N-A ... 2348154763
How can what appears to be a standard fixed output alternator give a continuous 14.2 volts in my 1.8T and yet give out between 14.2 and 13.5 volts in Imartyns 3.2.
I am trying to ascertain what the charging regime is for the 3.2 with an AGM battery, is it static around 14.2 volts or floating to 13.5, anybody.
The starting price is ÂŁ329.99 ...!!Gixxer123 said:Thats the starting price, you then put the code in atbthe checkout. Comes in at 108.David C said:How are you getting ÂŁ108 ??Gixxer123 said:Just lookong at getting a new 096 agm bosch s5 battery for the 3.2, euros do one with the discount code for ÂŁ108 which I am happy with as they are only round the corner from me.
Are you checking voltage with a meter pushed into the cig lighter socket, see link below, as it appears 11.1 volts may indicate little or no charge going into the battery and 13.3 volts when car is running indicates only a trickle charge coming from the alternator which probably won`t keep the battery charged in normal running.I have been watching.my 3.2 is floats from 14.2 down as low as 13.3. I am trying the battery on mine first, as its only showing.11.1v.
Handy to know the alternator is the same though, thanks
