Anyone sourced a haldex stepping motor?
270 views 6 replies 5 participants last post by  0h4ttquattro
The epoxy on my haldex motor became brittle, detached and caused a failure with no codes. Swapping controllers solved the issue.
Had anyone sourced a motor?
Idk why there is some graphite paste under the epoxy? I removed the pieces that were causing the motor to lock up and it spins freely now, but I'd like to source a motor.
No reply when I emailed the company direct
Hey @0h4ttquattro, that's a strange one, having the epoxy fail and jam the motor without throwing any codes. Have you been able to find a part number on the motor itself? Adding that detail might help someone here point you toward a supplier.
