(A) G107 - Sunlight Photo sensor linked to the Climatronic system. The system needs to adjust the fan speed and temp flap to maintain the temp set on the display. With more sunlight it assumes, for example, more cold air is required to maintain the temp set on the display.
(B) K133 - Alarm LED
FYI - There's another light sensor built into the instrument pod (arrow) which controls the dash lights. You'll notice this working if you have your DLR on and you go through a tunnel; the gauges dim out, but the needles remain illuminated.
