Hi Forum,
Do any of you guys know if a duff number plate light causes the "Bulb Failure" warning symbol to flag up in the display - even when the lights are off.
The "Bulb Failure" symbol has appeared briefly a couple of times in last few days while driving.
It's intermittent so I checked out all the lights and the only suspect was the off-side number plate light which wasn't working.
I tested the bulb with a Multimeter and it was fine. There didn't appear to be a problem with the 12v supply either and no corrosion or moisture.
When refitted the light actually started working again . . . till I closed the boot . . . then it went out. A quick thump on the boot lid brought the light back on again.
I have ordered the complete replacement light unit from Euro Car Parts which I hope will cure the issue.
Is there anywhere else I could try looking if this doesn't solve the issue?
I think my 2002 Audi TT Quattro has reached that age where it is throwing up one niggling little problem after the other . . . nothing big . . . just irritating and difficult to get at.
Would appreciate any advice.
