41 - 60 of 2,673 Posts
Hi all!
I have my car with xenon plus and I wonder if i can enable the dynamic rear indicators.
By the moment i enabled the followinf options:
- Traffic sign recognition
- Timerlap ( lap timer as TTS )
- Display OPS sensors in the rear screen ( screen exit the car with the rear sensors)
- Turning on demand of daytime running lights
- Mirror the passenger to get back up is down and then automatically returns to its position
Thank you!
Regards.
Discussion starter · #43 ·
Igonher said:
Hi all!
Thank you!
Regards.
Tell me how you have activated lap timer and the passenger mirror.. I tried my own guide but it didn't work!
Do you have electric seats?
Hi Manu!
For passenger mirror(i havent electric seats) i followed the guide from http://ankk-vagcom.com/tt-8s-abaisser-l ... #more-8512
[52 - Porte Passager] -> [Codage- 07] -> [Assistant Codage Long]
Octet 04 :
Bit 2 : Cocher « Reverse Gear Mirror Dipping active »
Bit 3 : Cocher « Position Memory for Reverse Gear Mirror Dipping active »
For lap timer i followed your guide. After change the bite 3 you have to access to car setup and select lap timer. For me work!
Discussion starter · #45 ·
Same guides as mine.. I did them several times but for the mirror,vag accepts coding but if I check again, there are not bit checked anymore..
Do you have foldable mirrors?
Instead laptimer, coding accepted but nothing on the menu...
I think is a 50/50 fault between my car and my vag..
I didn't know rear indicator weren't dynamic with xeno so I've never looked for them but I'll do it ok!
I havent foldable mirrors, only have electric mirrors. maybe you have problems with your vagcom cable? i'm using 15.7 version and havent problem, everything is ok! Tomorrow i will check the exact menu of laptimer and upload a image.
Thanks for looking if is possible activate dynamic rear indicators with xenon plus!
I think it is possible because the taillights are the same, right?
Discussion starter · #48 ·
Disable automatic reset for the auto high beam assist:
Unit 9
Access 31347
Adaption, channel 5 assistenzlichtfunktionen-beam headlights assistant reset
Change to active.
Now everytime we turn off the car and then on, the high beam assist will remain active
if you don't have that channel 5, you must have channel 5 fernlichtassistent and change it from active to not active
Hey guys,
New the this forum but not new to VAG or Vagcom. I have the full version and have been trying to get Ross-Tech to update their modules for our cars Mk3 TT/TTS so that we can use the long-coding helper.
Has anyone found success deciphering what is in there now? I even loaded the latest Beta version of vagcom and it still has not updated with the long coding helper channels deciphered.
Not sure if its different for the american TTS vs Europe...?
Discussion starter · #52 ·
After few tries, I think there is some differences in the market because with someone has labels on any bit with 14.10.2 and I have not.. Or some coding is accepted to someone and someone not.. Of course TT from different market
Access to open a module on the cars isn't just down to vcds
If everyone has the latest genuine 15.7 vcds software and some can open a module and read the values and some cannot then that means you have different modules in your car which I guess Ross tech haven't got round to covering them all yet
Best to contact Ross tech with your query and you module part number
On iPhone using Tapacrap
Discussion starter · #54 ·
Ok but sometimes some unit doesn't open in a car and in another yes even using the same vag or older version I'm waiting the update!
(My car is possessed!)
Have you not got a genuine vcds manutt ??
Discussion starter · #56 ·
not anymore...but I tried after bought the car with a 14.10 and I had the same problem so I didn't buy it again... I'll try with a 15.7 copy next week then if it doesn't work, I presume is my car! or is too soon even for Rosstech!
So you've got a ÂŁ30 - ÂŁ40k car and a ÂŁ10 copy lead and wounder why it don't do what you want [emoji23][emoji23]
ANY copy you buy won't be up to date for a mk3 TT
"IF" you get a 15.7 copy it will still be outdated as the copies are ALWAYs behind
Genuine is now on 15.7.3
Well worth the ÂŁ250 for a genuine mate and you get the support from Ross tech directly and all future free updates of sw
Discussion starter · #58 ·
I agree with you but on the mk2 I had the original, since I added many thing after bought the car..but on this one, I used vag only to deactivate the seat belt alarm and change few parameters otherwise I don't need vag com at all today..
Discussion starter · #59 ·
here we are...I'm trying to help you with the dynamic lights but I need another check from your parameters.
I confirm that these are all the settings for the intensity of any led and its direction, talked with a friend who did the same thing on a Golf... after changed all parameters, I hope it'll work automatically!
for security reasons, copy your coding and do it at your own risk, it's only a turn light but these things are very delicate!
the unit is the 9, I found the activation sequence but there are 665 parameters to check...I'll post here some of them and tell me if ANY parameters is the same as mine!
Light configuration from the (1) to (665)
(1)-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten
(2)-Light configuration-BAP Bitposition 0,34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Light configuration-Lichtfunktion A 0,2
(5)-Light configuration-Lichtfunktion B 0,0
(6)-Light configuration-Dimmwert AB 0,127
(7)-Light configuration-Lichtansteuerung HD AB 0,Always
(8)-Light configuration-Lichtfunktion C 0,3
(9)-Light configuration-Lichtfunktion D 0,0
(10)-Light configuration-Dimmwert CD 0,0
(11)-Light configuration-Dimming Direction CD 0,maximize
(12)-Light configuration-Lichtfunktion E 0,0
(13)-Light configuration-Lichtfunktion F 0,0
(14)-Light configuration-Dimmwert EF 0,0
(15)-Light configuration-Dimming Direction EF 0,maximize
(16)-Light configuration-Lichtfunktion G 0,0
(17)-Light configuration-Lichtfunktion H 0,0
(18)-Light configuration-Dimmwert GH 0,0
(19)-Light configuration-Dimming Direction GH 0,maximize
(20)-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten
(21)-Light configuration-BAP Bitposition 1,3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
(23)-Light configuration-Lichtfunktion A 1,4
(24)-Light configuration-Lichtfunktion B 1,0
(25)-Light configuration-Dimmwert AB 1,127
(26)-Light configuration-Lichtansteuerung HD AB 1,Always
(27)-Light configuration-Lichtfunktion C 1,5
(28)-Light configuration-Lichtfunktion D 1,0
(29)-Light configuration-Dimmwert CD 1,0
(30)-Light configuration-Dimming Direction CD 1,maximize
(31)-Light configuration-Lichtfunktion E 1,0
(32)-Light configuration-Lichtfunktion F 1,0
(33)-Light configuration-Dimmwert EF 1,0
(34)-Light configuration-Dimming Direction EF 1,maximize
(35)-Light configuration-Lichtfunktion G 1,0
(36)-Light configuration-Lichtfunktion H 1,0
(37)-Light configuration-Dimmwert GH 1,0
(38)-Light configuration-Dimming Direction GH 1,maximize
(39)-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(40)-Light configuration-BAP Bitposition 2,48
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
(42)-Light configuration-Lichtfunktion A 2,8
(43)-Light configuration-Lichtfunktion B 2,9
(44)-Light configuration-Dimmwert AB 2,28
(45)-Light configuration-Lichtansteuerung HD AB 2,Always
(46)-Light configuration-Lichtfunktion C 2,30
(47)-Light configuration-Lichtfunktion D 2,0
(48)-Light configuration-Dimmwert CD 2,28
(49)-Light configuration-Dimming Direction CD 2,maximize
(50)-Light configuration-Lichtfunktion E 2,20
if someone wants the full list of my parameters, I'll send it via pm or email..it's very long!
