Chamshaft timing issue
1.8K views 5 replies 4 participants last post by  Harm_1
TT 2003 180PS AUQ was without problems. Replaced valve cover gasket and halve moon gasket because some oil leakage in sparkplug holes. Was convinced that camshaft chain was as before when I closed the valve cover.
Now after 40-70km I get a motor error:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
So, I'm not sure about the camshaft in-out positions anymore.
Opened the valve cover again and rolled the car in TDC position. What do you think of the In and OUT camshaft positions? Is it correct or should intake camshaft 1 chain back (counter clockwise)?
OUT:
IN:
CHAIN:
Is it possible to compress chain tensioner (without unmounting) and 'free' IN-camshaft to shift one chain-link?
Any help appreciated.
Harm
Have you cleared the faults and tried again? In case the errors appeared after mucking about with it?
Anyway....
You should be able to just push it down with your hand, although I have never tried it with the head on the car.
Use a socket on the crank and turn anti clockwise a tiny bit to align the inlet cam, then jam the inlet with a piece of wood or something then turn the crank a tiny bit clockwise then recount the rollers... (you cannot turn the inlet cam back using the nut under the camshaft position sensor cover to wind the inlet back, it will just undo)
I have to say the roller count looks pretty good.
It is possibly an error with one of the sensors. If you did not remove the timing belt or chain there will be no reason for the physical timing to have changed.
The cam sensor is within the field of work fir replacing the gaskets, check that it is correctly plugged in and the wiring is not damaged.
Still error
but now intermittent and engine light doesn't come on for some weeks now.
During investigation I've lost locking clip for Camshaft position sensor (G40). What's the mating connector for this sensor (3-pins)?
