Clear Lacquer finish for brake calipers - which one?
9.4K views 33 replies 10 participants last post by  happychappy
Hi all
I have been cleaning and de-rusting a front caliper and am nearly there, as it looks pretty good I am loathe to finish it in a colour and would like to go for a clear coat.
Has anyone ever used a high temperature lacquer on their calipers?
If so what brand?
I have found this and it seems well received
https://e-tech.uk.com/e-tech-xht-clear- ... emperature
What were your findings?
Any pitfalls?
Has it lasted?
Is this a sensible idea?
Or should I just paint them lurid pink.... :p
Duplicolor engine paint works great. I used the red matte finish for my calipers. I plan on painting my wife's Tig calipers next spring, also red, but will use the Duplicolor engine clear coat finish just for a different look.
DUPLI-COLOR® Supertherm 300º, 584.42.87 - Dupli-Color Red Spray Cans 400 ml
DUPLI-COLOR® Supertherm 500º, 584.42.04 - Dupli-Color 10 Clear Varnish Spray 400 ml
Hi, I've painted calipers on most of the cars I've owned.
I've used hammerite silver / black paint on with brush with good results and durability.
Hammerite spray paint silver / black, smoother finish (with good prep) and good durability.
I've painted calipers with standard Halfords primer, metallic spray paint and standard lacquer. Looked great and lasted longer than I owned the cars
On my TTS I have used simonoz tough spray paint in gloss black and have got excellent results, very smooth!
In my experience you do not need high temperature paints / lacquers
OCD! Me? How very dare you..... :p :p
The C5 is a VERY good idea!
Been reading about it in the thread I started for my wheels and am intending to get some to use on them, probably going to get the bigger bottle to use on the calipers now, what a fantastic suggestion!
Btw, is that a spec of dust I can see behind your dash? :p
More importantly, are all of your spokes lined up symmetrically when you view the car side on? Valves too?
Annoying when they're not, isn't it? :p
Would you guys go as far as to ensure the tread patterns align with spokes and valves too :twisted:
I carry a trolley jack & puck for this exact reason!
You will often find me after a roundabout re-aligning the spokes and valves....
Pesky corners...... :p
I did use this argument to purchase new tyres... :p
@craig_09 and others. Re your advice of avoiding breakdust buildup with the use of certain products. In my experience without any armour products I have a significant build up of break dust every two weeks. I thought brake dust build up was unavoidable with audis and I ask this as I asked our local car accessories wharehouse and they stated that as the dust comes off hot it will stick to everthing even with "armour" products on the alloys. Is this true or is your experience significantly different with the products you mentioned?
#21 ·
I contacted Hammerite with regards to advice about using their products on cparakeet callipers as there is no mention of this on their website.
I received an email from them saying that they don't make anything suitable and forwarded a link to Europarts for the Foliatec range of paints.
I would prefer to spray the calipers so will have to look elsewhere.
Foliatec do a 2 part spray now, don't know how good it is, I used VHT spray for mine, I primed, painted and lacquered, 3 coats of primer, 3 coats of paint and 3 lacquer, I'll add some pics later, I've included a video from Foliatec for you.
https://youtu.be/8ovJE0fqMQM?list=PLqIC ... MCFBla4Yij
#23 ·
That's a great spot! It's usually only the brush on Foliatec paint that seems to be sold in most places.
However after looking into the small print it appears that you have to activate the hardner to use the paint.
As I am doing one caliper at a time due to the amount of work it's taking to de-rust and clean/refurb each unit and also that I wish to get as little air into the system as possible this will work out at a can for each corner = very expensive!
What brand of paint did you use?
I used VHT high temp spray Nu-Cast™ IronSP997, it's a gun metal grey and looks great.
#26 ·
Where did you purchase the paint from? I am getting matches but they are all overseas! :eek:
Was the primer and lacquer all VHT?
Totally agree, the gun metal grey is the doggy doo dahs, looks like that's on the cards for me now, especially as my wheels are diamond cut over dark grey.
Thanks for the pictures, so satisfying to see someone else taking proper care of their car, I am especially loving that picture of the oven! Thats exactly why I only spray stuff when Mrs Happy is not around :p :p
