De-pinning and Replacing Damaged Connectors - Tail Light Non-OEM Fix Part II
19K views 41 replies 13 participants last post by  TT'sRevenge
This is all very interesting. 👍🏻 I’ve done the secondary ground wire mod on both rear light clusters, as per the instructions on here, and whilst it solved the problem I now have another issue with the RHS light cluster. With the lights on, the tail light is illuminated but only dimly. If the earth pin in the connector is now redundant having done the mod, what else could be causing the issue?
Thanks so much SJP! I somehow missed your reply but I will check this out tomorrow in daylight. It sounds like it could sort my issue out, otherwise I'm absolutely at a loss. 🙏 I'll post back once I've taken it off and done the extra mod. (It shouldn't take long as I'm a bloody expert at taking the sodding lights out with the number of times I've had to mess about with them! 🙄😄)
