For the V6, there appears to be a cure for turning off the ESP facility but leaving the ABS functional..
Disabling ESP on the V6 via VCDS coding
The ESP bit in the ECU controller 03 (ABS) is:
Soft
Code
ESP Bit
V
Original: 23049 = 101101000001001 ABS/ESP/EDL
-2048 = 100000000000 (ESP Bit)
New: 21001 = 101001000001001 ABS/EDL (no more ESP)
To perform it:
VCDS -> Coding -> 07 Login 40168
Coding 11 -> Enter 21001 in place of 23049 and "Do it" button
This coding may also apply to the 1.8 is somebody wants to try it.
Steve
Soft
Code
ESP Bit
V
To perform it:
Steve
