Download maps
17K views 60 replies 13 participants last post by  kevin#34
Hi,
Im trying to install new maps but when i access to the update menu on the gps option says "F" instead of "Y" and i can not start the update.
I used the VW maps. Can you provide me any source to download it?
Thank you
#6 · (Edited)
The maps on MyAudi are just a subset of the VW download with some unnecessary MIB1 files removed to make the download smaller.
These unnecessary files are simply ignored by the TT when you do an update, so won‘t make any difference to the install.
Link to VW maps.
Also you should check your maps entitlement under Engineering > System > Activation Keys
The key starting 023xxxxx indicates the last version of maps you are allowed to use.
The latest map version from 2021/06/21 require an entitlement to 0230002A.
No new update yet, unless you’re referring to the one released in June for the first half of 2021?
There will be another update towards the end of this year, probably late November / early December.
#18 · (Edited)
Looks correct. Just unzipping now...
Thanks for the spot. I'd been checking for hidden downloads on the VW site, but nothing yet. Hadn't thought to check the other VAG marques.
Edit: Confirmed, all good. 2022 maps updated to TT.
#23 ·
Downloaded EU update at the weekend and 7-Zip is fine with me. Not going through the download process again to check, but here are the hashes...
EU
MD5 Checksum: 4A3390F32FF257D20183CF26155E7BBF
SHA-1 Checksum: 8AC22E00171B1482E076301E8309C9F081D9F133
SHA-256 Checksum: 8FA17660F7F9DE03C469686AB4FC976AFF76CB3F69686D317BC8FF6C2945A7BD
SHA-512 Checksum: 047FB37FC6E96A25872D851F08BB56CE5B10357598A2F0FCEA6F7E2CF0C3793545D1C7A37229511277BBC25092C0789D3D5B06484D6ADCDA8273A50BA128105E
Checksum Utility
#28 ·
Your best bet would be to hash your download. Then you’d know if it was the file thats corrupt, or the version of 7-zip that’s broken.
Hash values and a link to a tool to calculate them in my previous post.
#29 ·
looks VW just changed its policy, and now for maps updating you must visit a dealer... :rolleyes:
#32 ·
I always had the option to re-download the maps that I am entitled to which is 2017/2018 map (the mid update). However I was never sure why do you have the access to the file in the first place after instal.
Its not like you can delete maps and then download them individually. You install the "whole Europe 14GB map" thats it...
