Downloading latest Nav map?
5K views 15 replies 8 participants last post by  Drift
Had my new TT for 3 months now and wanted to check if any new Nav maps are available. I went into MyAudi but can’t find a section that relates to the maps, have I missed something?
Currently it looks like the VW download site (an alternative source if you can’t get MyAudi to work) is broken. Just a blank page for me…
Its still linked from the main site here…
No luck so far getting any sense out of VW. Their “suggestion” is I visit the dealer to update maps, and don’t seem interested their website is defective. :rolleyes:
Note the VW download (when it works) will only be of use if you maps licence is still valid (initial 3 years of updates) or you’ve had it extended.
Okay, looks like you can still download, but you’ll need an VW account first. No need to register a vehicle, just create an account with an email. Then go to…
For maps compatible with the TT select e-Golf from 2017.
No sign of the November/December update yet though.
For some reason I can't get this update to install. I have the sd card as ExFAT and copied the files on as before. I think the engineering menu can see it is a navigation database. But when I try to install from standard menu it says nothing to install. In theory I have a license to 2030 fec 0230003f. I know my Audo Connect has expired, but I don't think that should matter. It's written WMPInfo.xml to it.
Any ideas?
Should have MIB1 and MIB2 folders in root together with metainfo2.txt.
FEC 0230003f should be fine. My car has something like that, and took the update without issue. This update requires 02300030 or greater.
The xml file is created by windows media player I think, and shouldn‘t cause any problems. I have one also. No valid connect anymore either, and it’s not required.
My initial thought, given you seem to have checked most everything else, would be…
a) corrupt download/unzip
b) faulty SD/USB media
Thanks for coming back to me.
I downloaded the zip twice, and unzipped using two different archivers on Mac. I'll try a different SD card in the morning. I noticed when I went to copy it on that the card already had a previous install on it. That said I don't remember if I had to try a different card. I'll have another bash tomorrow.
The other issue is cost of Audi Connect to get traffic, so may swap to CarPlay anyway. Not as nice, but using Google maps it would be free.
You mentioned using a Mac. I wonder if it’s worth trying to format/copy the files over with a windows machine. Worth a punt in case there’s a weird compatibility issue there?
