I have a 2006 mk2 3.2 with 124,000 on the clock, engine runs sweet as a nut and the car has been serviced at every interval, will it benefit from a carbon clean if it can have one or some alternative, any response would be much appreciated.
Probably not worth it then, Thanks for the infoSwissJetPilot said:
Just been quoted £500 for my 2006 3.2 V6SwissJetPilot said:Further research on this topic reveals soda blasting is only good when the head is off for cleaning the valve surfaces and cylinder head surfaces. However it's not abrasive enough to remove baked-on, heavy carbon deposits found inside the intake and on the back of the valve and valve stem. So it looks like walnut shells are the only way to go.
I did find a company in the UK advertising the following. Price range is from £250 (4 cylinder) to £600 (V10) plus VAT.
PMP Cars (BMW Specialist)
Unit 2 Holman Way
Nuneaton, CV11 4PN
tel. 07843 716 975
email: pmpcars@hotmail.com
£390 from BlackpoolmotorworksSolarblaze_uk said:And for the north of England..
http://blackpoolmotorworks.co.uk/servic ... g-de-coke/
It would seem garages are quite few and far between offering these walnut blast services.
Hi, can I ask why you wouldn't recommend them. I'm planning on going to them for a map soon as was considering the walnut blastingrepsol said:I had mine walnut blasted and injectors cleaned, a few weeks ago, it cost £360 at r tech but I wouldn't recommend them.
Found them to be a bunch of miserable sods and felt ignored most of the day. I asked for a full engine check up whilst they had it in bits and not one thing I asked for was done. Was made to feel it was too much trouble for them and they were only intrested in what it came in for.Craig_09 said:Hi, can I ask why you wouldn't recommend them. I'm planning on going to them for a map soon as was considering the walnut blastingrepsol said:I had mine walnut blasted and injectors cleaned, a few weeks ago, it cost £360 at r tech but I wouldn't recommend them.
I wouldn't base your decision on one bad reveiw/experience to be honest.Craig_09 said:Wow, thank you for your detailed review... Im shocked and disappointed. Ive been researching the best company to take my TTS for stage 2+ and was 100% set on these guys. Really unsure now.
Thanks for the info.. Created my own thread thanksC00P5TT5 said:I too have travelled to use rtech and yeah one or two of them can come across as being a bit miserable, but that's just a northern thing :wink:
Just make sure Nikki is there and you can guarantee that you will be happy with the work
