Hello forum,
I've had an engine heating issue (225 quattro - BAM engine) for some time and I'm trying to sort out with my mechanic with no success so far. Latest work was done today.
The problem: Both fans dont come on as they should. With the engine on, after driving and coming to a stop, the temp passes the 90C mark briefly and returns to 90. This is verified by aircon code 49 (ie no faulty dashpod). Goes up to maybe 105C and returns to 90C.
With the aircon on, both fans work with the engine running so no overheat.
Now if I turn the engine off, the temp will go at 3/4 and touch red zone. This is again verified by aircon code 49 and obviously the problem is that the two fans NEVER come on with the engine off.
So far we've replaced with new Audi parts:
-Main thermostat (this was an older problem; the thermostat was stuck open and the temp wouldn't rise to 90C)
-Green valve
-Fan controller box below the battery with new one.
-Dual thermoswitch on the radiator (this was done today)
We've also checked:
-The circulator aux pump is working when you turn off the engine (you can hear it)
-Both fans work without a problem (both low and high speeds). This is checked by removing the dual thermoswitch plug and shorting the pins with a pair of pliers. Shorting a different pair activates low or high fan speed.
Obviously now with hotter weather the problem intensifies. Any ideas? [smiley=bigcry.gif]
[smiley=book2.gif]
-Green valve
We've also checked:
[smiley=book2.gif]
