Hello, my dad recently purchased a 2002 TT 225.
He came to me after the purchase with the temp warning on as it was at 130C.
So I waited a day ran the car, thermostat opened which dropped temp but obviously carried on rising.
Put econ on as it should kick fans in. Didn't run any.
Have no low speed or high speed or after run.
Today removed both plugs powered both fans with a power probe on low and high speed both ran up when power supplies with power probe.
Removed thermal switch plug connector, bridged connectors only have low speed but no high speed on there when bridged.
Fuses on battery ok. 30amp and the bolt down 40amp.
Does this indicate the fan relay module is at fault for not running any of the fans. At my wits end.
