Status
Not open for further replies.
FAQ - Bose Amp Technical Information and Repair Guides
12K views 1 reply 1 participant last post by  SwissJetPilot
#1 · (Edited by Moderator)
Bose Amp Technical Information and Repair Guides -
For anyone with questions about the various revisions of the Bose Amp over the Mk2 production years, or who wants to trouble shoot and repair their Amp, here's some additional information on those topics. As always, the workshop manuals can be found in the Knowledge Base. Link here.
Replacing 8J0 035 223 A Amplifier with 8J0 035 223 F
https://www.ttforum.co.uk/forum/viewtop ... &t=1887089
Technical information and water ingress solutions -
Bose Technical Product Information
https://www.ttforum.co.uk/forum/viewtop ... &t=1924691
View attachment Bose Amp Technical Service Information.pdf
Additional notes about the Bose Amp circuit board repairs can be found in the following links -
DIY Bose Amp Repair
https://www.ttforum.co.uk/forum/viewtop ... 2&start=15
Repairing a BOSE Amp - Some Notes
https://www.ttforum.co.uk/forum/viewtop ... 9&t=555809
For anyone who wants to water-proof their Bose Amp circuit board, here's some information on what to use and how to do it -
Bose Amp Circuit Board Conformal Coating Protection
https://www.ttforum.co.uk/forum/viewtop ... &t=1888669
Locating and Removing the Bose Amp -
The Bose Amp is located in the trunk, behind the left side panel and mounted to the back side of the wheel well. In order to remove it, the trunk floor deck, rear plastic panel, left side trunk panel and left styrofoam tool bin need to be removed first. Once accessible, remove the bracket nuts and release all of the electrical connectors.
Tools required - T30 Torx and 10mm wrench
When re-installing, check that the clips are still in the panels and not in the metal work of the chassis. Also check that the rubber seal is not pinched along the edge of the rear plastic panel. Instructions are applicable to both Coupes and Roadsters.
AUDI TT MK2 BOSE AMPLIFIER REMOVAL
Pictures courtesy of AMP-Performance AMP Performace
Status
