Shown below is the 2-piece insulation panel found on my 3.2 VR6 Roadster. The front panel is black plastic, while the rear panel is aluminum. This particular arrangement requires three different bolts to hold it all together -
For additional reference, these are the belly pans listed for the TTS and TTRS - (FNChaos)
For a complete list of Part Numbers available for the Mk2 belly pan click here to view the LLLParts website.
If in doubt about which pan works with your vehicle, take your VIN to a local Audi Service center and have them look it up.
Additional information on the fasteners is listed below.
The frame to which the aluminum pan is attached is referred to as a "Support Radiator Front" part number 8J7802017K
2-piece belly pan shown on the left, 1-piece belly pan shown on the right.
• WHT000729A for the Plastic Panel (Qty 13) - Torx 25
• N10644401 for the Aluminum Panel (Qty 10) - Torx 30
• N91009701 for the Aluminum Panel (Qty 1) - Tripple Square 8mm
• P/N for TTS = 8J8825235A / 8J8825237A
• P/N for TTRS = 8J0825237D
