Anyone have a how to for fitting a dash cam,which ignition controlled fuse to piggyback and route for the cable from the fuse box to the camera thanks
haha no worries glad it helpsaudilover88 said:sean mate thats a fab idea. You sir are a genius..I've stolen your idea![]()
Where did you get the hard wire kit from? I need to put my nextbase 412GW in lolSeanTTS said:haha no worries glad it helpsaudilover88 said:sean mate thats a fab idea. You sir are a genius..I've stolen your idea![]()
http://www.halfords.com/technology/dash ... 7Qodq4sP4gLollypop86 said:Where did you get the hard wire kit from? I need to put my nextbase 412GW in lol J xx
Thanks HoggsterHoggy said:http://www.halfords.com/technology/dash ... 7Qodq4sP4gLollypop86 said:Where did you get the hard wire kit from? I need to put my nextbase 412GW in lol J xx
Hoggy.![]()
This is possible but fuses are rated to protect the secondary equipment not the power supply. There is a fuse further up the line to protect the fusebox power feed. I would be more concerned if someone needed to up-rate the 1st fuse as it was supplying power to both items. This is not a good idea.brianmcc51 said:There is debate as to which is correct When fitted where the additional item is fused separately it would be theoretically possible to overload the original wire supplying the fuse,but when fitted the other way the original fuse would protect the car wiring.
