Hi has anyone created their own aftermarket fuel line? The original part new is pretty expensive and would like to renew mine soon.
The quick release connectors I did yes, new jubilee clips though.Aescilus said:Ah thanks yes I can see new lines there, I know there is a load of crap out there, there are specific hoses that allow ethanol through which are better, did you reuse the plastic clips from your old hoses ?
desertstorm said:I reused the clips off the old fuel line and made up some new lines using Mocal braided fuel line. Very high quality black nylon braided outer with steel reinforcing and a neoprene inner.
Nice! Is that the exact part that I need? That you used? Also have you relocated the fuel filter!?
https://www.ebay.co.uk/itm/MOCAL-G210-6 ... 1376618696?
Cohline-2192 (googled it in UK shops too), a very soft and supple hose, 7.5x13mm is the correct size, 1 metre is enough for the job.
