WoRkZ said:
Hello everyone!
I am currently replacing my crappy Symphony head unit for a new 9" Android 10 unit. I know there's been a few of you who talked about using the OEM mic... and I think I even remember someone talking about using the OEM antennas.
Now, I promise I DID look in the knowledge base... and then did a search in the forum. But I was not able to find solid info on this. Is the OEM mic reusable for the new radio?
Theoretically you could, but you would have to wire up the wires to the mic into whatever the radio accepts, which is
usually a 3.5mm mono miniplug. TBH it's not really worth wasting your time and the results might not be good if the sensitivity is different, though granted most HUs have adjustment for mic level as well.
WoRkZ said:
What are those two antenna connectors for that come into the back of the OEM radio. I suppose there's no GPS antenna in my car since there was no OEM GPS unit. But there are two antenna connectors... and one is for FM. But what is the other one for and can I use it for 4G or GPS at all?
The factory radios use a diversity tuner system. Basically it uses two antennas to improve reception. You can look this up online if you want more info on how it works but pretty much no aftermarket HUs have diversity tuning anymore. Back in the day Sony's higher end units had diversity tuning capability but haven't heard of this existing in the aftermarket in a long time.
As for the GPS antenna, if you have the sharkfin (which I believe pretty much all cars do) then you have the GPS antenna. The rooftop antennas are all standard and they are triple-function antennas. They have sat radio, "telematics" (basically a cellphone antenna that is never used since forever), and then GPS. So there's three fakra connectors coming off (I'll get to fakra in a minute). The blue is GPS, the red is telematics and the green is sat. radio. Most cars have the Sirius tuner so that's where the green one goes to. The red one almost certainly goes nowhere but depends on your model year, but not really relevant anyway.
So the blue one is GPS. Now there's two ways this can be wired if you
don't have the factory nav. One is that the antenna doesn't connect anywhere and the plug is just dangling/taped near the antenna. The second way is, it is wired as if the car
did have factory nav and ends up behind the radio. This is a bonus if you have this already.
As mentioned these are Fakra connectors coming off the antenna. Basically an SMB antenna connection with a colour coded housing. The colour coding is designed so only blue can plug into blue, only green can plug into green, and so forth. However you can "bypass" this by simply using a cable with Fakra teal connection which is universal--it fits any of the coloured connectors. The Fakra colours also have a corresponding letter--for example blue I think is C while green is E... The universal/teal one is called Fakra Z.
So, how to use this GPS antenna? Either way you will need an adapter for Fakra to whatever connection your aftermarket HU uses for GPS. It used to be that some of these connectors/adapters can be very hard to come by but these days with AliExpress and stuff you can basically get anything you need if you're willing to wait the month or two it takes to get to you. If you have the blue Fakra behind the radio all you will need is a short 3-6" adapter for the antenna connector you have and that's that. I suggest you simply get one with Fakra Z on the one end instead of worrying about C/Blue in particular, then on the other end the connection you need. If you
don't have the wire behind there you'll have to find the wire in the back either under the side trim on the driver's side or the headliner trim near the antenna--how long the wires go or where they were taped to can vary. In this case you will need a longer wire, let's say 10-12ft for a TT (maybe even shorter but always better to have a longer wire than you need). You can either use a cable with the correct ends or a cable with both ends Fakra and then the adapter cable.
Finally, the cable that comes off the antenna is male Fakra for the GPS I believe, while the other two are female Fakras.
But if you have the cable in there already the end that plugs into the RNS-E is female--so whether you have the cable or not will determine what gender connectors/cables you need.
If any of that is confusing, lol, let me know and I'll try to clear it up for you.
WoRkZ said:
Any assistance would be appreciated... and beer is on me for anyone who helps me use any of the OEM stuff (disclaimer: I am in Canada
Hooray for Canada--me too
