Unlike the Audi TT Mk2 1.8, 2.0 or 2.5 liter engines, the 3.2 VR-6 (BUB) Pollution Control Valve (PCV) diaphragm is located inside the Valve Cover "hump" directly behind the oil cap. Inside that hump, you'll find the Cyclone Oil Separator (COS) and inside the COS you'll find the PCV diaphragm (aka Vacuum Valve). Unfortunately, neither the COS or PCV diaphragm are available as individual replacement parts. Instead Audi will happily sell you the entire valve cover for around $425. If you have it replaced by Audi Service, expect to shell out somewhere around $800 for parts and labor. Keep in mind that's $800 to replace a $35 part!
This post will discuss the option of simply replacing the TT vent tube with a Touareg vent tube which has an external PCV diaphragm built in. It's a simple one-to-one swap with only a minor modification that anyone can do themselves.
At some point in time, that internal diaphragm will fail, and when it does the MIL light will come on and the OBD will register one of these faults; 18711, P2279 or 008825 indicating a leak in Air Intake System. In addition to the MIL light, the engine may get a bit lumpy, and when you open the hood, you'll hear a whistle coming from the back of the valve cover out of a tiny little vent hole above where the vent tube connects from the valve cover to the intake manifold.
You can see and hear it demonstrated in this YouTube video for a VW R32 MkV Golf -
Vacuum Leak VW R32
www.youtube.com/watch?v=Wl7guwee8u0&t
Fortunately, you can buy a non-OEM diaphragm as an individual part for around $30 (USD) from a third party such as RKX Tech. However you still have to remove the intake manifold and valve cover, and of course replace all the respective gaskets when putting it all back together. If you want to see what's involved in replacing the PCV diaphragm watch this YouTube video -
How to: VW & Audi 3.6, 3.2 PCV valve membrane replacement
www.youtube.com/watch?v=PmI-oH8wMRc&t=1s
V6-3.2ltr PCV/CCV Failure & Replacement
https://www.ttforum.co.uk/forum/viewtop ... &p=9043581
After a bit of research on other PCV designs for other VAG engines, I discovered that the VW Toureg uses a similar breather tube but with the PCV diaphragm built in which is designed to sit externally to the valve cover. So it's much easier to get to when the diaphragm fails. Both the TT Breather Tube and Toureg PCV tube have the N79 Heating Element connector and the overall geometry is identical so it a simple one-to-one swap.
FYI - if you get the following fault code - 18711/P2279/008825 - Leak in Air Intake System - this can be related to a faulty Positive Crankcase Ventilation (PCV) System or the N79 Heating Element.
TT vent tube on top, Touareg vent tube below -
OEM TT vent tube on the left replaced with a Touareg PCV vent tube on the right -
(Image credit A3-Quattro.de)
Vacuum Leak VW R32
