This is really a very straight forward DIY project and doesn't require a lot of technical skill, so don't be put off just because the wiring diagram looks a bit complicated. As long as you have the right equipment (RNS-E with RFSL), hardware (Reverse Camera, Video Media Module, 12-V relay, etc.) access to VCDS for re-coding and some basic wire splicing skills, you should be able to do this job in about 4-5 hours depending on your level of skill and experience with these kind of projects.
NOTE - Since this post is getting a bit long in the tooth some of the links may no longer work. So you may have to do a bit of on-line research for some of the parts which are suggested for this mod.
👉 VERY IMPORTANT!!!
The first thing you need to do is to verify your RNS-E unit is capable of accepting a reverse signal. To do this, you'll need to pull out the RNS-E so you can check the label on the top of the unit.
1.) Be sure to check the ID tag on the top of your RNS-E unit (see pictures)
a.) If you have "C: Ext Control Connector: 2. RFSL" the screen will auto-switch to the camera view when the RNS-E is turned on and reverse gear is selected. (RFSL is German for Rückfahrsignalleitung or Reversing Signal Cable)
b.) If you have "C: Ext Control Connector: 2. N.C." your unit is NOT capable of auto-switching. In this case, you will have manually select the [Media] / [CD/TV] button on the front panel in order to see the camera view.
c.) If you have an RNS-E that is not the original factory unit for your car (e.g. second hand from eBay or some other re-seller, etc.) there's a possibility that it does not have RFSL even if the label says it does. There have been reports of 'fake labels' and the RNS-E unit doesn't actually have the RFSL circuitry. Please see the link below for more information. If your unit is suspect, check the trouble shooting section on Page 33 for how to test if it the unit has RFSL capability or not.
🔥 Warning to anyone buying RNS-E on eBay
https://www.ttforum.co.uk/forum/viewtop ... &t=1283849
2.) This project requires access to a VCDS in order to code the RNS-E to recognize the reverse camera. However, if you don't have one, you can always have a local garage or a friend who has a VCDS do the code change for you. It doesn't matter if you have it done before or after you've installed the camera hardware, just as long as it's done as noted here in the VCDS Controller. See Page 2.
3.) If you have a pre or early 2007 model, your license plate lights may have screw-holes as shown below. Unfortunately the camera recommended for this project will not fit into this opening. Also, this particular camera is getting more difficult to find and can be stupid expensive. So you may want to go with a different camera. See page 40.
NOTE - There are a lot of cameras on the market listed as applicable for the TT, but few actually fit the TT license plate light opening as well as the Candid version. Look carefully at the picture below of the factory TT (8J) license plate light and the Candid reverse camera. The overall dimensions are exactly the same and it even takes the OEM lamp. If you buy a camera that's not like this one, it may not fit properly or the design may result in reduced light to the licence plate. Here's an open box review of the Zemex camera I ordered from Amazon which is exactly like the Candid camera.
📕 Audi TT Mk2 (8J) Reverse Camera - Open Box Review
https://www.ttforum.co.uk/forum/viewtop ... &t=1575921
REVERSING CAMERA WITH OPS
For anyone who wants to tackle this project, there's a great post by MT-VS for installing an OPS (Optical Parking System) and reverse camera from an Audi R8 system, which includes a reversing camera with moving guidelines as well as reverse parking and parallel parking modes.
📕 Reversing camera with OPS
https://www.ttforum.co.uk/forum/viewtop ... &t=1921981
📕 How to: Retrofit front parking sensors with OPS
https://www.ttforum.co.uk/forum/viewtop ... &hilit=OPS
PARTS LIST & QUICK REFERENCE LINKS -
Here's a parts list and wiring diagram for the reverse camera installation project by ReTTro fit. For anyone using the KunSet multimedia adapter, please see post on page 18 of this thread which includes a modified wiring diagram and KunSet source (- thanks Poder!)
1.) Media Adapter
a.) Adapter Universe ® Multimedia Interface Adaptor IMA RNS-E Symphony 3 TV Video Cable
http://www.amazon.co.uk/Adapter-Univers ... ideo+Cable
b.) Ampire video converter module -
https://www.ampire.de/RL-RNSE.htm?Sessi ... SE&p=15087
Note - this unit is more "plug-and-play" and does not require splicing into the Block D connector.
2.) RNS-E Removal Keys (x4)
http://www.amazon.co.uk/Audi-Headunit-R ... s+%28x4%29
3.) Male-to-male Audio Video AV Extension Cable
a.) Standard RCA extension -
http://www.amazon.co.uk/Heavy-Phono-Ext ... +extension
b.) RCA Male Jack Adapters - useful for Roadsters or where routing the RCA Jack is difficult -
Sourcingmap® Adapter Lautsprecher-RCA-Kabel auf AV Cinch-Stecker, 10 Stück : Amazon.de: Elektronik & Foto
4.) 10 meters, 2-core black/red, 12-V Extension Wire
Used in conjunction with the RCA Male Jack Adapters for easier routing of the RCA connector - http://www.amazon.co.uk/METERS-BLACK-EX ... s=12V+wire
5.) Wire connectors
a.) 3M Splice Connectors - industry standard.
http://www.amazon.co.uk/SPLICE-SCOTCH-C ... connectors
b.) T-Tap Connectors - For small gauge wires, as found with those in this project, the "T-Tap" connectors are really easy to use and provide a solid, reliable connection -
(UK) https://www.amazon.co.uk/Wire-Connector ... B07DK6GVL8
(USA) https://www.amazon.com/Alightings-Conne ... B017FT5G4S
c.) Heat Shrink Self-Solder Butt Splice Connectors
https://www.ttforum.co.uk/forum/viewtop ... &t=1846569
6.) Fused On/Off 4-Pin Relay 12V 30A Normally Open Contacts
Recommended to provide "clean" non-PWM 12-V power signal to the camera. Note - If you can't find a relay with the fuse built-in, you can use a standard 4-Pin relay and add an 30A in-line fuse between the battery and relay (Pin-30).
a.) Relay -
http://www.amazon.co.uk/Fused-4-Pin-Rel ... B00I9E8WRM
b.) In-line fuse -
https://www.amazon.co.uk/Cocar-Electron ... B01J1NAISU
7.) Repair wire for Quadlock - Audi P/N 000 979 034E
Audi factory part only
8.) Cloth electrical tape
Identical to OEM tape found in wiring harnesses. Much better than the plastic electrical tape -
https://www.amazon.co.uk/Cloth-Tape-TES ... B01554NGG0
9.) Reverse Camera (may also advertised for Audi A4L, A1, Q5) Model Number: 86-852, Brand: CANDID
NOTE (27/03/2021) If the links below are no longer good, try a Google search for "Reverse Camera for Audi A4L, A1, Q5" or "Candid Model Number 86-852" -
Note that the camera shown in this write up will replace the LEFT license plate light. If your camera arrives with the camera on the left side of the assembly, then use it to replace the RIGHT license plate light. The point is to install it so the camera is closest to the vehicle center-line.
10.) Optional - VCDS/VAGCOM
To order a VCDS check with Ross Tech in the USA - Ross-Tech: Home
For those here in Europe, the Ross Tech HEX-V2 connectors and cables are available on Amazon.de and Amazon.co.uk
https://www.amazon.de/HEX-V2-Ross-Tech- ... =ross+tech
https://www.amazon.co.uk/HEX-v2-Version ... =ross+tech
NOTE - At the time of this writing, it's not known if it's possible to make the required code change with an OBD-2 device; (e.g. OBDeleven, Carista, etc).
11.) Piggy-Back Fuse Accessory Tap
If you need to tap power off the fuse block for the media adapter, here's some information on how to install a piggy-back fuse tap correctly -
📕 FAQ - Adding a Piggy-Back Fuse Tap & Fuse Locations
https://www.ttforum.co.uk/forum/viewtop ... &t=1849573
12.) Roadster Wire Routing and Panel Removal
Routing the wires is a bit more of a challenge with a Roadster. You'll need to remove the trunk liner, route the wires through the rubber tube grommet on the left side of the deck lid (page 31), and then run the wires from the trunk, through the bulkhead, under the door sill, up the driver's kick panel and across to the RNS-E.
Every comes out pretty easily. Just be sure to check for broken or missing clips before you re-install the panels.
📕 How to: Audi TT Mk2 Roadster Trunk Lid Panel Removal
Link here.
📕 How to: Audi TT Mk2 Roadster Seat Rear Panel Removal
Link here.
📕 How to: Audi TT Mk2 Roadster Trunk-to-Cabin Wiring Route
Link here.
🤬 TROUBLE SHOOTING GUIDE -
A summary of problems and fixes related to this project can be found here (page 32)
https://www.ttforum.co.uk/forum/viewtop ... 7#p9025767
For anyone with a RNS-E screen that's starting to look bad because the anti-glare coating is coming off, here's a DIY to solve the problem -
📕 How to: Audi TT Mk2 (8J) RNS-E Screen Anti-Glare Repair
https://www.ttforum.co.uk/forum/viewtop ... &t=1777249
🔧🔨 ALTERNATE REVERSE CAMERA OPTIONS -
If you find yourself without an RNS-E or if yours doesn't have RFSL, there are a couple of aftermarket options for a reverse camera. One is a dash mounted version, the other is a mirror kit that fits over the OEM mirror. Both are discussed here -
https://www.ttforum.co.uk/forum/viewtop ... 7#p9048737
For anyone interested in how to, or how not to, install a reverse camera for an Xtron headunit, here's a post by 'John 949' you may find helpful -
https://www.ttforum.co.uk/forum/viewtop ... &t=1883329
UPDATE - If the recommended camera is not available, you can retrofit the OEM light assembly with any no-name reverse camera as shown in this new DIY -
📕 DIY - Retrofit OEM License Plate Light & Reverse Camera
https://www.ttforum.co.uk/forum/viewtop ... &t=2004707
If you have access to a 3D printer, I've designed a reverse camera mounting plate similar to the Motormax design. You can read more about it, and download the STL file in this post -
📕 Mk2 Forum 3D Printing Post - Latest Projects
https://www.ttforum.co.uk/forum/viewtop ... 9#p9455819
👉 VERY IMPORTANT!!!
1.) Media Adapter
5.) Wire connectors
a.) Relay -
b.) In-line fuse -
Link here.
Link here.
Link here.
