21 - 40 of 104 Posts
Not sure what the diagnosis was to rule out steering rack but the car doesn't:
Drift in any direction
No loose feeling in the steering
Steering doesn't pull
No vibration in steering
Some common signs I suppose ^^ which could make sense if there is a knock when turning.
The indie who does the work is genuine and unlike some who would see ££££ and not rule out the rack.
The knock obviously got worse with the car lowered some obviously more load = bigger knock. Also the knock is also apparent when im going up a slight curb.
Ideally would be nice to have someone with the same fault (which there seems to be a few of) have theres solved as its not nice spending money to narrow down to eventually fixing the cause.
mickee92 said:
Well I had my car in and on the lift and nothing obvious. Not the steering rack than god!!
Checked all bolts to see if any where loose but all seem ok.
Now I have had new top mounts and bearings on when the springs were put on so maybe they could be making a creaking noise? More prominent when stationary and going lock to lock and slightly when manoeuvring even when not turning the wheel and going up kerbs.
These subframe collar kits might be the next addition as there's nothing else that is visibly wrong. Is there a part number for them or where to get?
Bolts won't appear to be loose, but they are a 1 use only stretch bolt to a torque plus 90 degrees.
As I wrote before, highly recommend changing these! They stretch over time and will allow the frame to move.
Should be x6 main frame bolts (m12? with 18mm heads), 4 in the rack, 4 in the wishbone bush (m10? with 16mm heads) and if you wanted x4 (m8, 13mm head) antiroll bar bush brackets. All of those (minus the ARB bolts) cost me sub £50 from TPS trade account, if you're worried about spending money that may not fix the issue but I can't see it being much else with what you've replaced.
If you reread my previous post mine was exactly the same, even with the kit but when I hadn't replaced everyone of the bolts mentioned above. More noticeable at low speeds and drop curbs.
If you wanted a subframe locking kit, I personally went Tyrol as the above mentioned issues and seen how well designed they were first hand. I ordered direct from them: http://www.tyrolsport.com/suspension/ch ... 2-audi-tt/
Sorry I just looked straight at the link for the kit and saw £170+ for it and was reluctant to get that straight away. £50ish for the bolts etc will be worth it then as I've had the front subframe off 3-5times recently for work on the centre prop, manifolds and other stuff. Cheers.
my steering wheel is having some knock to it, only when it's cold. The steering wheel is traveling like, in steps or something, can't describe it, but it feels as it's not smooth at all, . The motion itself is like turning the rack-wheel of a catapult, in clicks, it pushes back:
I think it might be the steering rack motor as I already changed the cable loom. Could it be something in the drivetrain itself? Or the steering column? After about 15 minutes of driving it goes away. A video of the problem:
grantlack said:
TyrolSport sells them machined from brass, and 034 motorsports sells them in stainless. The brass may be a better choice than stainless steel in regards to metallic interaction with the aluminium subframe. Galvanic corrosion is no good.
Correct.
The problem with steering knocks is there's a lot of moving parts in the steering chain. I'd be looking at bush wear first.
Roller Skate said:
Correct.
I believe this is where the investigation will start with mine. There was a note in the service report from January this year that said the rear ARB bushes were slightly split but it wasn't serious enough to warrant an advisory note on the MOT done in July. If this is the case the dealer has agreed to foot the bill since worn bushes are classed as wear and tear and as such won't be covered by the warranty.
Bloody hell no wonder you have noise if those bolts have been reused that many times! Lucky none have sheared heads off with that amount of use haha :lol:
What torques have you been redoing them to?
Most definitely get yourself some fresh ones if you know the frame now isn't going to come off for a while and I bet the noise will be silenced.
I'll report back when I drive it again at the weekend.
Mine does it at low speeds as well as when stationary. It's booked in to be looked at this weekend.
I picked my car up from the garage this morning. They could hear the noise that I mentioned but they couldn't find anything that needed replacing or fixing. It's definitely not the steering rack. Their best guess is that it's slightly worn ARB bushes but not worn enough to justify replacing them. Their advice is to keep an eye (and ear) on it and go back to them if it gets any worse.
I'm glad that there's nothing seriously wrong but it's also frustrating that there's nothing that can be fixed.
Thanks for the update. Mine does this when reversing. Drives fine otherwise.
Last time I'm going to try typing it :lol:
Subframe bolts!
It's well known and documented about the stretch of these bolts across the vag cars, allowing the subframe to move (sometimes fractionally - sometimes a lot) causing creaking that can stay as that or worsen to knocking.
For the sake of undoing and torqueing 6 or 10 or 14 bolts (subframe + rack + ARB) at around £50 its massively worth trying at the very least.
But as I have wrote in this thread, I have had the exact same issue and it has been solved.
I'm glad yours was sorted but, as I said, they didn't find anything wrong on mine. They checked the rack and the ARB with the car on the ramp. If the subframe bolt issue is well-known and documented then they will have known about it.
Only so many times you can bang your head against a brick wall :lol:
Believing that any mechanic knows everything to do with any car seems madness to me.
Even specialist garages won't know everything, even if they are massively knowledgeable firm, which your personal mechanic/garage probably is, the will still be a fault they've never seen or had to research.
You can't find a fault with a stretched stretch bolt, It won't have any appearance or be "untorqued" (which what is the torque figure, when its spec'd XXX ft-lbs + 90 degree turn..) Unless you're bothering to take it out and check the TPI count and/or shank length, very very accurately. If they had of done that (which obviously you wouldn't with the cost of the bolts or without the knowledge about the issue) they would definitely know that they'd need to replace the one use only stretch bolt.
You seem desperate for a fix with your previous reply, which I'm not surprised with as its massive irritating, yet aren't willing to take any advice, when its been proven to work.
This is only using VW, not audi, vag, etc... Plenty of information amongst loads of threads:
https://www.google.co.uk/search?q=vw+su ... fW8gegy6BI
https://www.google.co.uk/search?rls=com ... Hbo2O67-90
Please just use some of the links on the 1st pages of that search, you'll see what I'm talking a.bout, maybe you won't make a comment, questioning other peoples knowledge who might actually know something..
There's shit loads more, as blokes S3 at work before I even had purchased TT was exactly the same. Well his creak turned into clunking. But he's anal, he researched it so much, with a little of my help. There's so much information on this issue.
2 positive results, on 2 cars with that issue. But continue listening to the noise if that's what you'd prefer than trying a £50 and 30 minutes of your own time solution, with a ratchet and torque wrench.
Does anyone have a part number list for the sub frame bolts that require changing? I have this noise and after changing the drop links / top mounts and the car not having any advisories on the MOT last week - It must be this that is the cause.
Is it a simple driveway job with the car on axel stands and a breaker bar and torque wrench?
Where did I say that I believe any mechanic knows everything to do with any car? The garage that I took it to is a VAG specialist; the owner's daily driver is an 8J TTRS. I believe that he would know about this issue (and if it's what's wrong with my car) since, as you've demonstrated, it's well-known and well-documented. It's not my personal garage. I've never been there before. It's local to where I bought the car.
Obviously I'd like to get it sorted but I'm not desperate: it's a mildly-irritating sound. Why do you think I'm unwilling to take advice? I'm more than willing to listen to what anyone has to say about this issue.
Why the attitude? I'm not questioning your or anyone else's knowledge about this. I'm just saying that maybe what you're suggesting isn't what's wrong with my car. It doesn't really sound like any of the clips on those pages.
Again, why the attitude?
I will be doing what barr_end has suggested as to be fair I've had my subframe off and on quite a bit this year with exhaust/manifolds & centre prop faults so could well explain the knock for me.
Now the videos you shared are the exact same sound I'm hearin when doing the same stationary turning. I've had it looked at and checked over with and nothing to be too obvious.
For the £50 or so to replace the subframe bolts etc then Its no biggy and I will be getting my transmission mount replaced which will need the frame dropped again so I will replace the bolts.
If nobody else sorts this out before me then I will pop back in January when the work has been done.
Hopefully Barr_end is right so he can get a very reluctant thank you :lol: :wink:
With how you wrote the reply, I believed you was questioning my knowledge as you were acting as if it wasn't documented or known, and clearly I've dealt with the issue not once, but twice. And with the amount of times of typing and seemingly no-one wanting to listen and try, I assumed people would much rather just live with it.
I have Dyslexia so I can read things wrong, so if you weren't questioning or having the attitude I interrupted it to my replies, then I apologise, if you found my reply conflicting or insulting.
The sound clips linked in this thread I find are poor, I can barely hear them on the laptop and sound odd on my phone.
Personally I'd ignore those as an aid in finding your car.
The 2 main causes of any front end creaking/clunking will be topmounts or subframe, IF it is not the rack as those are the main 3 known 'weak' points on this year of vag cars. I'd start with the cheaper options - bolts then mounts purely down to cost and likeliness of what's causing the issue.
Hence my insistency that one of you guys with the issue would take the chance on the subframe bolts as I think you'd be pleasantly surprised that it will probably fix the irritating noise.
calletso said:
Is anyone able to confirm this is the correct part number for the sub frame bolts and I just need 2 of them?
N-908-235-01
ETA: Where can I get these from as nearest Audi dealer is 55 miles from me?
I missed this, I'll see if I can ring TPS up and get a copy of my invoice to confirm numbers:
They'll be x2 bolts for the rear of the frame which are different, then x4 bolts for the rest.
x8 bolts for the rack and rear wishbone houses.
TPS would be a good place to get them if there is one any closer.
