I have a 2008 3.2 S Line with adaptive bi-xenon headlights, and my left side high beam recently stopped working. It's my understanding that both the low and high beams use the same bulb, and it's just a shutter that opens/closes to switch between the two. I can see this working on the right side, but nothing happens on the left, and then after about 4-5 seconds the right shutter closes and its back to the low beam only. I do have a "left main beam headlight" warning on the information panel. The bulb obviously works, and I've even tried with a replacement. Could it be the ballast, or a problem with the shutter itself? Is there any way to repair the shutter other than replacing the entire headlight assembly?
