Overheating
4K views 17 replies 6 participants last post by  StuartDB
Hi, I have a 2001 TT Quattro 225 which overheats when driving above 50 mph. The previous owner advised he recently changed the Timing belt and water pump along with the radiator, fans and thermostat. The temperature gauge goes up quite fast and the alarm sounds when it enters the red. If a drive slowly in a high gear it drops back to about 90. I removed the thermostat completely which helps it stay cool a little longer but it still runs hot and the radiator is always cold. I don't think it's the pump as it looked new when I removed the stat so I am thinking if the head gasket is on it's way out would the extra pressure stop the water circulating? The expansion tank always has pressure in it even when it's cold and whilst there is a little condensation on the oil cap the water looks clear and there is no white smoke or misfire. Any help will be greatly appreciated.
You shouldn't need to remove a thermostat! Is the air hot from the interior heaters?
What do you mean the water pump looks new?
The expansion tank always had a little psssttt when you open it from cold.
There are 6 types of head gasket failure! are you actually losing any coolant at all. Try flushing the coolant, maybe outs a persistent air lock?
Thank you for your responses. I will try the code 49 and let you know the result. The internal heater does get very hot, it's only the radiator that remains cold. When I had the stat out I could see the bright blue fins of the pump which does look new. Yes it is loosing water but not sure if that's because it's pushing it out the overflow or whether it's burning it
When it is getting too hot if you put the heater on full hot and the heater keeps blowing hot air and doesn't turn into less hot air, then that shows that coolant is at least circulating through that part of the system.
That does tend to suggest the pump is working so I will take radiator out and check the flow. I am thinking the head gasket may have gone and is pushing super hot air into the cooling system as the car does heat up very quickly. Not sure why that would stop the water circulating through the radiator though.
Its maybe pressurised the system so much.
Before committing to doing the head gasket, get the coolant sniffed, maybe garages will do it for free, and if you are getting head gasket done, have a think about any other work to do at the same time -
I cleaned throttle body, fitted 3 inch DP, powerpowerdogf lex, dog bone mount, coolant flush. I wish i did valve stem seals.
Hi, I have checked the water levels before and after running it and every time I check it after a run it has lost water. I have taken the stat out for now so that can't be an issue. Not sure about the timing being out, would this not make the car rum lumpy/slow as it pulls like a train? I doubt the impellers are broken as it supposed to be a new pump and looked ok when viewing it through the stat hole. I will check the radiator flow first in case that's a problem. I will be doing the head gasket myself so the cost will not be high.
Hi, It's possible the pump impellor is intact but it is spinning on the spindle. This was a problem on the original "plastic" pump but the later pump shouldn't have the same problem, but you never know.
Ok based upon all the above good advice I think I have a plan
1. Check the gauge is accurate as per the 49 trick. If ok :
2. Pull the radiator and check it's not blocked. If ok:
3. Take off the timing belt cover and check it's correctly aligned. If so:
4. Take out the water pump and check it's working. If ok change it for a metal one anyway and :
5. Remove the head and replace the gasket having changed the valve seals and cleaning the throttle body.
Have I missed anything ?
