p1136 (system lean) and p1297 (check DV) help
4.7K views 8 replies 5 participants last post by  StuartDB
2003 225hp BEA engine
Slowly getting this car back right. I thought I had everything fixed till CEL came on.
I got these code.
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 -
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-00 - System too Lean
More about the p1297 in a minute.
The P1136 code started after installing a FMIC ( because factory left intercool cracked) a new Fuel filter and cleaning the throttle body and doing an adaptation.
I have spent weeks looking for any kind of boost/vacuum leak. As of right now I can pressure up the system to 20psi and it will hold. I have emptied 4 cans of carb cleaner checking every gasket and hose. I can't find anything.
What else should I check? any more ideas?
On to the P1297.... This fault refuses to go away. I can clear the codes, and then instantly reread the codes and it is back.
Ideas? are they related?
Thanks for the help again.
Sir Jaymz said:
No one has any ideas? I'm not getting any responses on Facebook either. Do I word my question wrong?
Maybe have patience with the forum. You posted a mere 10 hours ago. Is also the weekend when folks are busy.
Sent from my SM-G930F using Tapatalk
I apologise. I didn't mean to come across as rude or demanding. I honestly thought my wording was confusing.
I have deleted the n249 valve and have a new DV. I checked the old DV before and after removing it and it is still good. I deleted the n249 valve thinking that was the issue.
The code come back instantly. I might get a video the next time the car is home. But basically if I am sitting on the drive way, and clear the codes. The rmp rise a little then go back to where they we're (maybe 1 second of time soes by) then if I read the codes again the "Check DV" code is back.
I apologise again for my impatience
Are there 2 pressure sensors and one is faulty?
There is a maf sensor and the map sensor. Have you logged the car eg, maf, vacuum/boost maybe your maf is correct and your map sensor is low so not adding the correct amount of fuel, then the o2 sensor is seeing a lean reading.
But I wouldn't go round buying random sensors based on a guess, log the car instead. Even android torque pro cram read, maf, boost, afr
if the afr is > 1 that's too lean.
