Passenger window problem?
463 views 6 replies 5 participants last post by  barney4300
Noticed the other day that when I touch the window close or open switch for the passenger window it no longer goes all the way down or up. I have to hold the switch until it is up or down.
Any ideas, I have service due in 2900 miles might be best to wait till then and get it sorted on warranty.
Just a very quick touch should move the window all the way down (or up) and a held press will use control mode which will stop the window when you release the switch. If this is not the case then definitely report this to your dealer and get it looked at.
Audi and their windows..... :-/
Cheers,
Scotty.
This is a known problem. I had it on mine. I can't quite remember what the process is to reset. Something like open both windows fully, then close again.
Someone will be along with the exact sequence I'm sure, is it on Waks or Kevins site? or in the FAQ?
This happens quite regularly on mine.
try this
ignition on, but not the engine
press and hold down switch - window all the way down
press and hold up switch - window all the way up and hold for about 5 seconds
after that it should be ok
John
