Roadster Roof Stopped Working Mid-Opening
150 views 9 replies 4 participants last post by  philipcrolfe
I’ve just treated the roof and opened it a few inches, then went to move it slightly and it didn’t move, the display said there was an error!
I’ve had the car from new 2099, never had an opening issue before.
i continued switching the ignition on and off with a pause between trying to operate and after 5 or 6 attempts it finally started to work, does anyone have have any ideas on the reason for this?
What’s the state of your car battery? - low volts can cause issues with electric operation of many things. If it’s still on the original battery, I’d check it out as it might need changing.
I've never had this particular problem with my roadster, though I have replaced both flap servos - those can prevent the car from acknowledging that the top is completely down. However, I had this problem with my wife's 2007 Bentley GTC. It would stop at random times in the up or down process. I finally determined that the roof position potentiometer was bad so the roof controller couldn't tell where the top was. The TT uses hall sensors and microswitches, rather than a potentiometer, so one of those may be bad. I'm pretty sure there are switches in the roof latches, so if it's halting soon after releasing from the windshield, it could be one of those.
