Speaker wire colours for concert amp
22K views 30 replies 11 participants last post by  dewem
Hey guys, new to the group. I'm trying to replace the concert amp but I need to know the colours of the speaker wires for each speaker please. Had a search but can't see them on here apart from the bose amp? Any help will be appreciated.
Sorry, don't know. But very easy to test for yourself....
Get an assistant and an AA or AAA battery. Connect the battery across each of the pairs of wires in turn. Usually tape or hold one of the wires to the bottom of the battery and use a scraping/flicking action with the other across the top of the cell works best. Your assistant should easily be able to identify which speakers are driven from which set of wires.
HTH.
Edit: For polarity, I would guess the brown in each set is negative.
#31 ·
HTH.
auto parts bmw
The typical speaker wire colors for a Concert amp are:
Front Left: White (+) / White with Black stripe (-)
Front Right: Gray (+) / Gray with Black stripe (-)
Rear Left: Green (+) / Green with Black stripe (-)
Rear Right: Purple (+) / Purple with Black stripe (-)
Check your vehicle’s specific wiring diagram to confirm, as colors can vary by year and model.
HTH.
I did start doing that by plugging the wires one by one into the amp. I've found the tweeters but I stopped as one pair of wires tripped the head unit. I can tell the power and ground wires for the app it's self so I'm guessing it's got a mic lead. Hopefully someone will have a colour chart, fingers crossed.
It hasn't got a name as such. It's just the "Standard Sound System" amp as opposed to the Bose Amp. The "Basic Sound System" has no amp in the boot with a reduced number of speakers being powered directly from the HU.
#9 · (Edited by Moderator)
Here's SSP382 which covers the Basic, Standard and Bose sound systems. Unfortunately it only shows a general wiring diagrams and does not include the color codes -
View attachment SSP 382 Audi TT Coupé ‘07 - Infotainment and Spoiler.pdf
NOTE - Image is from SSP382, Audi TT Coupe '07 Electrical and Infotainment Systems (also available in the KB with other SSPs). Colors and polarity are from the Workshop Manual Wiring Diagrams & Component Locations A005TT20021.
For Bose Surround Sound -
RIGHT -
• R158 Center Midrange: (-) br/gr (+) ro/gr
• R22 Right Front Treble Speaker: (-) br (+) ws
• R104 Right Front Midrange Speaker: (-) br (+) sw
• R23 Right Front Bass Speaker: (-) br/gr (+) ro/gr
• R160 Right Rear Mid/Low Range Speaker: (-) br (+) bl
• R16 Right Rear Treble Speaker: (-) br (+) bl
LEFT -
• R148 Center Speaker: (-) br/sw (+) ws/sw
• R20 Left Front Treble Speaker: (-) br (+) ro
• R103 Left Front Midrange Speaker: (-) br (+) ro
• R21 Left Front Bass Speaker: (-) br/ro (+) ro
• R159 Left Rear Mid/Low Range Speaker: (-) br (+) ro
• R14 Left Rear Treble Speaker:: (-) br (+) ro
164 Microphone Unit
J526 Digital Sound System Control Module
ws = white, sw = black, ro = red, br = brown, gn = green, bl = blue
gr = grey, li = lilac ,ge = yellow, or = orange, rs = pink
Stavy1683 said:
tttony said:
These are what you need.
That is awesome! do you have the original doc or link please as I can't make out the letters on the wires.
Thanks for that! :D
Yep, totally illegible unfortunately.
Would probably help if images were saved and uploaded as PNGs, and not JPGs. JPG lossy compression sucks for legibility on logos and diagrams. :p
These are the pin designations for the plug into the amp:
NON-BOSE AUDIO AMP PIN OUTS
The audio pins in/outs on the 32 pin connector to the amp in the boot are:-
Line Level Inputs
25 Green 0.35 Rear Left Line In
27 Blue 0.35 Front Left Line In
30 Red 0.35 Rear Right Line In
32 Yellow 0.35 Front Right Line In
Speaker Outputs
03 Brown/Red AND Brown 1.00 Front Left Bass - AND Front Left Treb - respectively
04 Red AND Red 1.00 Front Left Bass + AND Front Left Treb + respectively
06 Brown/Green 1.00 Rear Left Speakers -
07 Red/Green 1.00 Rear Left Speakers +
15 Brown/Grey AND Brown 1.00 Front Right Bass - AND Front Right Treb - respectively
16 Red/Grey AND White 1.00 Front Right Bass + AND Front Right Treb + respectively
18 Brown/White 1.00 Rear Right Speakers -
19 Blue/White 1.00 Rear Right Speakers +
20 Brown/Grey 1.00 Front Centre Speaker -
21 red/Grey 1.00 Front Speaker +
Ground Connections
24, 26, 29, 31 Brown 0.35 Ground Connected Together In Loom Then One Cable To HU
There are other pins for power etc.
All or some of the pin numbers should be moulded on the connectors. The cables from pins 25,27,30 &32 go to pins in the blue connector block on the HU
Line Level Inputs
Speaker Outputs
Ground Connections
Legend! thank you
#21 ·
Really helpful thanks, but i found that the wiring on my 2008 TT door speakers were the REVERSE of the wiring noted in the diagrams, ie the Right door wiring matched up to the Left diagram and vice versa. All wired up and working and sounding great, but hopefully useful info for the next person pulling their hair out!
#22 · (Edited by Moderator)
This was a super helpful post to me. Thank you to everyone who contributed.
I'm also wiring up an RNS-E but I have a couple of specific questions and could use some guidance if possible.
A bit of background:
I bought my 2008 Audi TT coupe secondhand. The original owner installed an aftermarket head unit, all new speakers, and 2 4-channel amps.
During the CPO process, the dealership removed most of the aftermarket stereo stuff and kindly put it in a large cardboard box. They then installed the original Audi Symphony head unit. The speakers were left in place, but several of them were never connected. The amps were removed. The aftermarket head unit was removed.
My goal:
I'm now looking to reinstall the 2 amps (details lower), reconnect all the speakers and replace the factory head unit with an Audi RNS-E Nav unit (details below).
My gear:
Head Unit:
Audi TT RNS-E upgraded unit (part 8J0 035 193 F).
Amps:
I have 2 identical 4-channel amps. They are u-Dimension ProX Series. (http://www.chpw.de/indexud.htm)
Speakers:
The car has 11 speakers total. They are also made by u-Dimension and seem to be good quality.
A bass and a mid in each of the front doors - 4
A tweeter on either side of the dash - 2
A center speaker on the dash - 1 (this one is factory and may not even be connected)
Mid speakers behind driver and passenger - 2
Tweeters behind driver and passenger - 2
There might be a subwoofer in the passenger side of the trunk area, under the felt cover. I haven't checked yet.
Wiring:
There are wires running to all of the door speakers, and judging by the way the front tweeters are wired, the aftermarket speakers were connected to the existing factory wires.
Antenna:
At some point my factory shark-fin antenna broke and I replaced it with a Q5 antenna that I bought on eBay. I didn't realize it at the time, but the Q5 antenna came with a 3rd lead for the GPS! So I'm thinking to use that for the GPS signal, and run a Fakra extension from it to the RNS-E.
I read as many of your posts as I could find.
I ordered up and AUX connector to be able to connect a phone to my RNSE https://www.amazon.com/Input-Cable-...2-PIN/dp/B07YB12TM8/ref=sr_1_1?dchild=1&keywords=rnse+aux&qid=1617035360&sr=8-1
I don't believe the car originally had Bose, but if I find that there is a PIN in B7, I'll move it to B5 as per other threads.
I also found a pretty good solution to get the amp connections from the Quadlock using this harness: https://www.discountcarstereo.com/aih-rns.html
Now for the fun stuff....
Questions:
1) To get signal to my amps, I'd like to use the line outs from the RNS-E.
As I read, the RNS-E has lines out for 4 channels (FR, FL, RR, RL). Am I right in using the harness above or can I simply find these same leads at the amp in the trunk (see photo). Judging from the tape, I'm guessing the previous installers tapped into the lines here in the trunk. If I can avoid having to run new wires, I'd rather do that.
2) I'll also need a remote-ON wire for the amps. Is there a chance I can find it in the trunk by the factory amp or do I have to run it from PIN 13 of D section of the Quad Lock?
3) Am I right in using the GPS lead from the shark fin and running a Fakra Female-Female extension to the back of the RNS-E.
4) In the rear passenger compartment, there are 2 speakers on the driver's side (mid + tweeter)...but 3 speakers on the passenger side. What is that 3rd speaker? Is it for the parking sensor?
5) If I'd like to add a Bluetooth module for the telephone...would now be a good time to do that? Is there a guide for this?
I'll probably have more questions, but these are the main ones that I'm grappling with now.
Thanks so much in advance for any advice you can send my way.
#23 ·
@ dbk - While I applaud your efforts, as an RNS-E Bose Sound System owner myself, you may be throwing good money after bad. Unless you are a big fan of retro-head units, the RNS-E wasn't that fantastic when it came out and Bose Amp failures are notorious for giving up the ghost every time it rains - ask any Coupe owner who has one.
Rather than trying to resurrect what the dealer's butcher did to the sound system, you might be better off (and money ahead) going with a newer, "modern" head unit like Xtron or something similar. At least you've have a 'real' Bluetooth capable unit unlike the now decade old RNS-E. And with an Android head unit you can use it as a display for a OBD scanner like OBDeleven.
There's some pretty good write ups on a number of different systems and many forum members are well versed in putting one together so if you opt to go that route, there's lots of help available.
Ultimate after-market head unit review thread
https://www.ttforum.co.uk/forum/viewtop ... &t=1369753
FAQ - Xtron Installation Information
https://www.ttforum.co.uk/forum/viewtop ... &t=1963311
If on the other hand you are fully committed to retrofitting an RNS-E, you might want to download and read this workshop manual and SSP as they will provide you with a good source of information to compliment the wiring diagrams. And just an FYI, some RNS-E models can be set up with a reverse camera so I've provided a link for that too -
• Communications - RG 91 - D3E8006B7D9
• SSP 382 Audi TT Coupé '07 - Electrical & Infotainment
How To - Audi TT Mk2 Reverse Camera Installation
https://www.ttforum.co.uk/forum/viewtopic.php?t=981945
Thanks SwissJetPilot! Super helpful and detailed as always. I decided to go for the RNS-E because of the original look. I won't be using the factory amp, but suppling power with a pair of nice aftermarket amps. I also have all aftermarket speakers. I got a good deal on the RNS-E so that is why I wanted to give it a try.
https://www.ebay.com/itm/2010-2015-...F-Excellent/333925456138?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
If I hate it, I can always replace with aftermarket and keep the rest of the components as is.
I was just not 100% sure whether I need to run wires from the head unit directly or if I can pick up the line-out signals from the rear amp. If you can clarify this, that would be a major help.
Thanks again!!
P.S. That Xtrons looks pretty slick BTW. I wish I knew about it before I ordered the RNS-E. I'm not too worried though. I can always swap out :)
#25 ·
Hopefully you received the PIN number from the seller. Unfortunately I'm not the guy to provide any assistance with hooking up an RNS-E. Installing a reverse camera based on instructions provided by Rettro fit is the limit of my audio knowledge.
Fortunately there are several other Forum members who are very knowledgeable. :D
