Stainless T25 Torx trim screws - where from please? :)
5.5K views 16 replies 11 participants last post by  alexgreyhead
#1 · (Edited by Moderator)
Hello folks,
Shed has a number of the underside T25 Torx trim screws either missing or replaced with mild steel versions which have rusted faster than my dad's old 2CV.
Would anybody know where I can buy a big bag of them, please?
Thanks!
Al
#6 · (Edited by Moderator)
Thanks TT-Dru but I'm 95% certain those are the mild steel ones I already have a bag of.
The backup option is to buy a new lot, rinse them in brake cleaner, spray them in zinc primer and then coat in Bilt Hamber or ACF50 once they're screwed in, but they'll still go rusty so it seems like a pointless mission.
The screws are apparently No. 10 size by either 5/8" (16ish mm) or 3/4" (20ish mm).
With the random screw I have lying next to my desk, my ChineseBay calipers give me measurements of 0.18"/4.7mm thread, 0.77"/20mm length, 0.58"/14.7mm head diameter.
Apart from the wider head, this is a very commonly-available stainless screw size on fleabay, e.g. 100 of these are ÂŁ6.64:
Or 100 of these allen-headed screws would be ÂŁ7.99:
Or these Torx head screws - ÂŁ6.40 for 100:
All three have slightly smaller heads, so I would probably also want a bag of 100 of these M5 x 15mm x 1mm washers at ÂŁ3.70:
I guess the question would then be, do I go for screws which look more like the existing Torx head screws, or allen-head bolts which look a bit more "proper" than having random screws dotted around?
I'm definitely not keen on the idea of paying ÂŁ20+ for a small handful of the "proper" screws... :x
/Al
alexgreyhead said:
The problem is they seize into the captive metal spring washer things they screw into, so they're impossible to remove unless you drill them out, snap them, or snap the mountings :(
Cheers fella, yeh i can see why that wouldnt be ideal then
Thread resurrection
I don't own a TT but have been searching for months for some stainless replacements for the screws which attach the mudflaps to my B6 A4 Avant. My searches kept throwing up this thread asking the same question. Well I finally found it, they're on eBay but no mention of torx etc; they're sold as numberplate/bumper screws and I've just received them from Hong Kong from this seller: https://www.ebay.co.uk/itm/8pcs-5-x...cense-Plate/401755569899?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2648
The seller also has different size threads/lengths so I think you'll be able to get the ones for the arch liners/undertrays too although I've yet to try that but these are certainly a good replacement for the mudflap ones although the flange isn't quite as wide. I was a bit skeptical about the black finish at first, I don't know if it's paint or some kind of plating (they're all bag marked anyway) so I soaked one in a solution of saltwater for a week and then left it to air dry - no rust. Anyway here's some pics, some with the 17yr old original for comparison:
I got a handful from a TT breaker locally and quite a few of the stainless ones were painted black, so it doesn't seem to be unusual.
Interesting link, thanks for posting them. I've been trying to get around to doing something on mine with these - the handful I got were destined to be stripped and plated, but I'm not sure it's worth the fiddle.
(Thread starter here) This is annoying - having forgotten I’d posted this thread, and in need of replacement screws because Shed’s rear valance screws appear to have gone missing, I Googled stainless torx trim screws for the Audi TT and ended up back here…
So, thank you Oldscholar for the recommendation - I’ve ordered £20-worth of those trim screws from the Chinesebay seller you linked.
If they ever arrive and I remember this thread, I will pop back in and update as to how good they are :)
Al
