NickG said:
By CCM is that the comfort control module??
As in this bugger...
If so i'd be really interested in your plans to delete the thing, as you say, there's a shed load of wiring for that thing!!
Just finished completing the bypass. It is pretty simple to do once you understand the function of the Comfort Control Module J429 (aka Control Moduke for Central Locking) and what the car is looking for in order to start. Let me first say that the module controls a host of operations and bypassing it might not be a good idea for a normal street car. The CCM overlooks things like central locking, anti-theft warning, and what interests us here, sending a power signal to the starter interlock relay J207 (obviously once all the proper conditions are meet).
So in normal operation, and once all the checks are performed by the CCM, it sends a power signal to the the J207 relay (that's what we want to simulate to get the car running without a CCM). This relay is located in the 13-fold realy panel in the #4 position.
Below is what the relay will look like, and you want to romove it and unclip the plug so you have easy access to pull the wires.
Here are the circuits labeled on the relay. You want to jumper circuit 85/86 and then 87/30 (separately). I just pulled the lines off the plug, labeled for future use, jumped the circuits shrink tubed and tuck everything away. Done!
As I thought, the CCM also references the clutch inhibitor switch F194. However, jumping J207 like mentioned is downstream of the clutch pedal position switch (CCP) and it can be simply left alone.
Here is a diagram of the circuits:
...and a link to the PDF:
http://mk1tt.montebellopark.com/pdf/200 ... Wiring.pdf
PS: Thanks to Matt and Adam for providing me with some much needed wiring diagrams for the car. You guys rock and allowed me to drop about 10 lbs of useless junk!
