Throttle body reset
10K views 13 replies 11 participants last post by  PlasticMac
Been doing some servicing on the tt today and decided to clean the throttle body and done a throttle body reset via vcds
What a difference the car runs and drives a lot smoother
Productive day
To follow on from this.
Tried doing VCDS reset today.
Switched basic settings on, selected 060, hit GO, and it sat at 2 for an age.
Wak says it should go to 8, but how long should this realistically take?
Do I need Wi-Fi connected as I wasn't connected at the time??
Any tips please.
Sent from TimBuckToo
Any tips please.
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen.
Once you do this you will see the top right display say ADP RUN.
The TB adaptation is being done as soon as you switched basic settings on.
You will see the values change and hear the TB cycle for the first few seconds then it will stop.
Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
If it did not complete, or resulted in Error, see the Special Notes below.
http://wiki.ross-tech.com/wiki/index.ph ... nment_(TBA)
Thanks mate. So it should cycle to level 8 within 30 seconds then?
I read that same bit from Ross Tech earlier today, but they mention nothing about going to level 8, just to wait 30 seconds.
Wak's Write up is on a very VERY old version of VAG-COM from many many years ago.
So things may have changed since then.
