Can anyone shed any light on whether this is a good idea? I'm aware of the advantages of not filling the intake manifold with carbon deposits (oil) but are there any draw backs from deleting, negative effects, mpg/performance etc
I'd happily pay that!QS Luke said:FNC I thought the sole benefit of PCV Delete was to almost negate the carbon buildup?
That said, ÂŁ350 to have the injectors serviced and inlet decoked isn't horrific and maybe that's a better option every few years?
Please tell me how this is a bad idea ??FNChaos said:PCV delete is a terrible idea. Nothing to be gained performance-wise and lots of downside. You can however replace your stock PCV valve with a catch can if your into wasting money :lol:
Maybe you'd see a 'slight' increase in reliability with a catch can (since there is no diaphragm to tear), but a catch can doesn't really serve it's intended purpose as it will not reduce carbon build-up on a DI motor.
But it does when the PCV is there, like it should be. With the PCV deleted, you already introduced a leak. An additional leak makes no difference then.Solarblaze_uk said:Removing the oil cap or dipstick with the pcv deleted has no effect on the car idling - it has no effect
There shouldn't be a vacuum in the engine. The PCV valve guides blow by gasses (gasses that leak past the cylinders and the pistons). There are 2 routes: straight into the intake manifold during idle and towards the turbo inlet while under boost.Solarblaze_uk said:The only immediate difference I noticed was that there was no vacuum (suction) on the oil cap and it didn't try to stall the car when removed - I guess that's because no air is getting to the intake that's unmetered.
What makes me wonder though, is, is it better there is vacuum (suction) in the lower half of the engine. Does it make a difference if that vacuum is removed. For that reason, I removed the pcv delete and went back to stock
Read up on what your PCV valve does then explain how deleting it is a good idea.andez1781 said:Please tell me how this is a bad idea ??
Yes. Your PCV system is vacuum dependent. Without vacuum, exhaust by-products that build up in your crankcase are not scavenged and removed. Instead they end up back in your motor oil.Solarblaze_uk said:What I wonder is, by deleting, removes the vacuum at the oil cap completely, and whether that has a negative effect on the engine
This is exactly why you have more build up. You are not effectively removing water vapor (among other things) from your crankcaseSolarblaze_uk said:I'm curious, have you done a pcv delete? I didn't notice this last year prior to deleting. I'm wondering if deleting is restricting the removal of condensation in the oil
Delta4 said:The PCV serves a purpose, if your concerned about oil vapor fit a catch can after the pcv not instead of.
You could add a catch can inline after the PVC valve but then you would need to add another one-way valve to prevent pressurizing the can during boost. Of course now we are talking about adding more valves instead of deleting them. :lol:Solarblaze_uk said:There doesn't seem to be any inline catch cans to intake readily available, which seems strange, as this would make complete sense - the gases get by, but oil gets catched so doesn't clog the valves
You could add a catch can inline after the PVC valve but then you would need to add another one-way valve to prevent pressurizing the can during boost. Of course now we are talking about adding more valves instead of deleting them. :lol:FNChaos said:Delta4 said:The PCV serves a purpose, if your concerned about oil vapor fit a catch can after the pcv not instead of.Solarblaze_uk said:There doesn't seem to be any inline catch cans to intake readily available, which seems strange, as this would make complete sense - the gases get by, but oil gets catched so doesn't clog the valves
Here is a site that demonstrates a myriad of ways to install catch cans.Delta4 said:Your wrong mate, you dont need to add anything else and the can will only see the same pressure/vacuum that the pcv see,s
I don't think you quite understand thisFNChaos said:Here is a site that demonstrates a myriad of ways to install catch cans.Delta4 said:Your wrong mate, you dont need to add anything else and the can will only see the same pressure/vacuum that the pcv see,s
https://damondmotorsports.com/blogs/damond-blog/53965956-bye-bye-blow-by
Note the use of an additional check valve in several set-ups to prevent crankcase over pressurization. Also note setups shown without check valves are not recommended.
You are , and others are over thinking it. :wink: Just remember the delete plates you get without a can , where you are pushing all that oil,fuel,water mix straight to.. no longer on the intake valves (and I've had mine apart to clean them) but now the back of your turbo .Solarblaze_uk said:I'm starting to think, I'm overthinking all of it, and it's all just best left as-is with a new valve replaced every few years just in case (they're cheap after all).
The advertising for deleting does come across as 'this is the best thing', but perhaps it's not quite so straight forward and a good run out frequently is more than enough to warrant the deletion.
English isn't my mother tongue, so I might be missing something here....andez1781 said:Just remember the delete plates you get without a can , where you are pushing all that oil,fuel,water mix straight to.. no longer on the intake valves (and I've had mine apart to clean them) but now the back of your turbo .
Yes to number two , let me explain , when your car is running off boost your the pcv valve runs open and all the crud goes straight to the intake manifold and as they are direct injection there is no fresh fuel to clean the back of the valves, it builds up unsightly amounts of carbon ( this is why more modern cars have direct injection and port injection at the same time) not the greatest but the valves can take a fair amount . Now if you're car is on boost you're pcv valve gets forced closed so not to pressurise the crankcase and all the gases and vapour are redirected to back of the intake which inturn goes to the the turbo ( have you ever opened the bottom of the intercooler , you will get a fright with the amount of oil/crud in it ) now having all that build up hitting the delicate turbo fins is definitely not a good thing without having a source of collection (catch can ).so that it why if you are to add a blanking plate to the pcv system to reduce the amount of crud going into the intake you really should use a collection system or it negates the reason for having it , that is unless you have a high boost setup and the reason for removing the pcv valve is to remove/ reduce the risk of it failing and inturn pressurising the crankcase... Done correctly there will be no unmetered air entering the system ..TT-driver said:English isn't my mother tongue, so I might be missing something here....andez1781 said:Just remember the delete plates you get without a can , where you are pushing all that oil,fuel,water mix straight to.. no longer on the intake valves (and I've had mine apart to clean them) but now the back of your turbo .
That oil, fuel, water and what have you mix goes to the back of your turbo?
To me that can mean 2 things:
1) it basically goes straight into the exhaust where it contaminates the catalytic converter.
or
2) it goes into the turbo, through the intercooler, through the intake manifold where it then passes the intake valves.
