Hi joined the forum in hopes to find a solution to my recently discovered problem.
I will try to keep this condensed as possible.
I have a 2008 coupe, its not really driven too much as I car pool to work.
I drive it probably a couple of times a week, but for the past 3-4ish weeks I haven't driven it much.
Awhile ago I noticed a lot of condensation on the windows, especially the windshield, found out the seal was bad, a few months ago had it replaced.
I was still noticing condensation on the windows but not as much, but it slowly seemed to be getting worse. A few days ago after work I noticed quite a bit of condensation so I decided to soak up all the water in case the temperature dipped to the freezing mark. While I was cleaning I needed to adjust the passenger side seat but it didn't work, I finished cleaning the windows and decided to check the seat the next day.
Next day looked up possible causes for the power seat not working etc, while checking the plugs and wiring and stuff I lifted up the cover to all the connectors under then seat and notice drops of water all over, I was like huh? I kept poking around and lifted the carpet up a bit so I could try and see anything, I was shocked to see that cavity filled with water! I'm guessing that the cause of why the seat wasn't working.
It seems to be only the passenger side, I took it for a drive yesterday and could hear the water sloshing around under the floor...I hit a small bump on the road and water flew out into the foot well. I tried to park on a hill facing up in hopes the water would drain out, but instead water started pool in the rear passenger foot well!
I live in British Columbia, Canada. In the previous few weeks it had snowed and rained quite a bit and during that time the car had been mostly been parked.
What are any possible causes of the ingress of water and how is the best way to drain it? If there are any other details needed please let me know.
Main priority right now is to drain the water.
I have searched the forum and read through this thread https://www.ttforum.co.uk/forum/viewtopic.php?f=19&t=1144209&p=6421297&hilit=drains#p6421297
searched through the MK2 TT Knowledge Base and anything to do with drainage and water, no luck
