What benefits do dump valves actually have? recirc + atmos
3.4K views 15 replies 12 participants last post by  ttsteve
ttsteve said:
Also - as I understand it from posts on here - you're not supposed to use dump valves with a TT. It's designed for use with a recirculating type.
You can always use the Forge splt-r in hybrid mode where it recirculates air and dumps as well. However as you may suspect, running it in such a mode will reduce throttle response because air that would otherwise be used is actually dumped. You get the pshhht sound though. PM me if you have any questions because I have changed 3 DVs so far and I have toyed around with them running them in different modes and settings. Very quickly:
If you run a remapped car and want the best possible performance choose the Forge 007p with the yellow spring. If you car is stock, green spring.
Short answer yes it does make a difference in the boost. At least that is what I think.
