Wheel Lug Nuts
3.4K views 4 replies 4 participants last post by  chelspeed
Looking to fancy up the wheel faces. Wondering if these open or close lug nuts can fit the TT? If so, are they are direct replacement and what size would they be? Are they also rims dependable? Current rim set is a BBS CIR.
Although a different model (I have CC-R) the holes on BBS wheels are quite tight (a lot tighter than OEM) so be careful about any lug nuts/bolts that use a larger sized head.
You cant fit wheel nuts (lug nuts are US only) as the TT uses wheel bolts as in Hoggy's picture rather than wheel nuts.
To fit the wheel nuts you show you'd first need to fit wheel studs to the hubs One example, not sure if it's the right size and thread for the TT but it's an example 20pcs 58mm M12 x 1.5 to M12 x 1.5 Wheel Stud Conversion Bolts for German Cars | eBay , the wheel would then be held onto the studs with open nuts rater than by bolts into the hub.
