Mk1 FAQ and knowledge base
This is a new FAQ structure. The index below links to other pages with more detail containing How Tos and tips etc. The best thing is that anyone can easily contribute a suggestion and then a mod can add it to the index
Please contribute any How Tos or tips you come across here: Contributions
Reviews and buying advice
General specifications, dimensions and capacities
Recalls and free upgrades
- Coilpacks: Replacement coilpack sticky - courtesy of Les.
Parts catalogue and Workshop manual information and practice
Engine
Fuel, pipelines and exhaust
Transmission
Bodywork Exterior
Paintwork
Window glass
Doors
- Door issues: Door fitting and problems with locks, alignment, microswitch etc.
Bodywork Interior
Interior modifications
- Aftermarket front seat replacement: Details fitting and airbag bypass issues - courtesy of TTQ2K2.
- Tourist Trophy: Where the TT gets its name from.
- "The Essential Buyer's Guide - Audi TT (8N)": Comprehensive published guide for buying a Mk1 TT - compiled by Mark Davies
- Buying advice: General advice on buying a TT - courtesy of dazzadrew1
- Buying advice websites: Buying advice websites - courtesy of Doug Short
- Buying a MK1 3.2 TT reviews: General advice specific to the 3.2TT.
- All things V6: V6 community information - courtesy of V6RUL.
- General advice: General car and TT buying advice - courtesy of John-H
- Average component life: Average Replacement/Failure Mileage Listing - started by djbite
- Photo gallery: Huge photo gallery of TTs!
- Dashpod Watchdog video: The notorious BBC Watchdog item that forced Audi to replace all faulty dashpods for free.
- MOT advice: MOT testing advice - useful check points - courtesy of shshivji.
- Bodywork dimensions: In 2D line drawing. Includes track and wheel base dimensions.
- Fluid capacities and specifications: Oil and coolant capacities along with VW specifications.
- Max gear speed: Maximum speed possible in each gear - courtesy of Doug Short.
- Dashpod Warning Symbols: From the quick reference guide - your first clue.
- Roadster Quick reference: Quick reference guide for roadster - Courtesy of Skee.
- Model list: Full list of Mk1 TT revisions - Courtesy of Dont I Recognise You.
- QS differences: List of differences between QS and 225 - Courtesy of Kanikuman and Doug Short.
- Build code information: General paint and code sticker information - Courtesy of Skee.
- VAG code search: Vehicle option code search - Courtesy of Skee.
- VAG option code list pdf: Vehicle option code listing in pdf form - Courtesy of Skee.
- VAG option code list: Vehicle option code listing - Courtesy of Skee.
- TT Coupe Self Study: VAG self study programme for the TT Coupe - Courtesy of volkspage.net
- TT Roadster Self Study: VAG self study programme for the TT Roadster. Click here to download the PDF.
- Parts catalogue: Complete catalogue of all parts with images for 1.8T - courtesy of mikesimbo.
- On line parts catalogue 1: On line source of Audi parts with useful information and diagrams etc.
- On line parts catalogue 2: On line source of Audi parts with useful information and diagrams etc.
- Service schedule: Service schedule from handbook - courtesy of John-H.
- Jacking: Safe jacking point - courtesy of John-H.
- Wooden ramps: Four point lift with wooden ramps - allows level fills etc. - courtesy of John-H.
Engine
- Maintenance: General maintenance and repair to keep you on the road and save you money.
- Fault finding and VAG-COM diagnostics: Diagnosing faults - methods and analysis.
- Tuning: Getting more power from your engine.
- Cosmetic: Bling for your engine
- Fuel pump: How to change your fuel pump - courtesy of lazerjules - also contains link provided by TTQ2K2 and notes by John-H
- Fuel filter: How to change your fuel filter - courtesy of John-H
- Fuel pump and sensor: Fuel pump and sensor guides - courtesy of ViperOneZero.
- Fuel pump diagnosis (pdf): Vag-Com diagnosis of fuelling issues with the fuel pump - courtesy of John-H.
- Fuel pump explained: How the fuel delivery system works and which pump to get - courtesy of steveupton.
- Rear silencer: How to change just your rear silencer box - courtesy of peter-ss
- Vacuum diagram: Vacuum diagram of pipework and components - courtesy of John-H.
- Turbo gasket: Replacing failed turbo gasker - courtesy of jonnyl888.
- Manifold-turbo bolts: How to remove painlessly- courtesy of nedge2k.
- Downpipe: How to replace the downpipe - courtesy of John-H.
Transmission
- Clutch replacement: Clutch servicing for a Mk1 TT Quattro - How To - Step by step guide courtesy of brian1978.
- Clutch pedal repair: Failed clutch pedal repair - How To - courtesy of Rosskie.
- Gearshift adjustment: Excellent video showing adjusting the gear linkage - courtesy of dieselgeekdotcom
- Gearshift adjustment locking pin: Locking pin discussion and demonstration - courtesy of dieselgeekdotcom
- Gearbox overrun whine: Easy shim fix - courtesy of TT-AL
- Driveshaft CV joint: Driveshaft CV joint removal - How To - courtesy of Random Hero - contributed by Cookie.
- Driveshaft outer CV joint video: Driveshaft CV joint removal - How To video - courtesy of Edge Motors.
- Driveshaft inner CV joint service: Driveshaft CV joint service (similar to TT) - How To - courtesy of Curtz of TDIclub.
- Gearbox oil change: Gearbox oil change - How To - courtesy of BaueruTc.
- Haldex Oil change-1: Haldex oil and filter change - How To - courtesy of Nick 225TT.
- Haldex Oil change-2: More Haldex oil and filter change advice - courtesy of John-H.
- Haldex and new tyres: Should you change all the tyres at once - True or false?
- Haldex explanation: VAG self study programme for Haldex - courtesy of Jez xbx
Bodywork Exterior
- Bodywork dimensions: In 2D line drawing and 3D model. Includes track and wheel base dimensions.
- Spoiler removal: Audi TT spoiler removal tech bulletin.
- Front bumper removal: Front bumper removal - courtesy of Wak
- Rear bumper removal: Rear bumper removal - courtesy of Wak
- Front grill removal: Front grill removal - courtesy of TT4PJ
- Soft top removal: Soft top removal to replace drainage pipes and cure wet boot - courtesy of DolomiteGreyTT
- V6 bottom grille : How to replace your V6 bottom grille - courtesy of DazHulme
- Side skirt (over sill) replacement : How to replace your outer sill cover skirt - courtesy of J5TTC
- Vinyl wrap fuel cap: How to vinyl wrap your fuel cap in pictures - courtesy of leeleegod
- Fuel filler cap screws: Fuel filler cap screw replacement Ho To - courtesy of Joss J55TTC.
- Grill refurbishment : How to refurb your grills with PlastiDip - courtesy of vanboosh.
- LCR splitter : How to fit an LCR splitter - courtesy of Blue TTop.
- Roadster roof drain : How to repair a roadster roof plastic drain skirt - courtesy of mutley100.
- Roadster roof glass : How to reattach the rear glass to a roadster top - courtesy of TTQ2K2.
Paintwork
- Cleaning polishing and detailing: Details of how to keep your paintwork in pristine condition.
- Paintwork repair: Repairing damage to paintwork.
- Paintwork protection: Ways to protect your paintwork.
- VAG Paint Codes: Volkswagon-Audi group paint codes and colour names (slow to load page - be patient).
Window glass
- Window cleaning and treatment: How to clean your glass, remove scratches and which rain dispersant treatments to use.
- Glass chip repair: Who to use for chip repair, what's allowed and even how to do it yourself.
- Replacement glass: Where to get replacement glass from, how to replace glass and issues involved.
- Door window: Problems with wind noise and jamming. Replacement glass fitting issues, how to replace and correctly adjust glass and issues involved with window regulator cable, motor, switches, Window Reset (drop, roll-back, one-touch), etc.
- Aerotwin wipers: Fitting Bosch retrofit Aerotwin wipers to older hook design arm - courtesy of John-H.
Doors
Bodywork Interior
- Remove OEM seats and replace with Porsche Recaro GT3s: Photographs of istallation - courtesy of TT2QK2.
- Seat height adjustment fix: How to fix a seized seat adjustment mechanism - courtesy of ViperOneZero
- Seat recline fix: How to fix the reclining mechanism - courtesy of MCIP
- Sound deadening: How to reduce annoying cabin noise - courtesy of wisptt.
- Trim removal: Removal of various trim - courtesy of laserjules
- Creaking parcel shelf: How to stop your parcel shelf creaking - courtesy of John-H
- Boot rattle: How to stop a boot rattle - courtesy of peter-ss
- Leather handbrake cover install: Instructions on how to replace the cover - courtesy of aidb
- Leather and trim codes: Leather interior trim codes - courtesy of Pukmeister
- Sliding drawer: Sliding drawer detail - courtesy of John-H
