01273 Blower failuer. Help SOLVED
34K views 8 replies 4 participants last post by  Shug750S
Got back from Holiday yesterday (it's been warm here) and my Air blower has packed up. The control unit all lights up ok just no blower. I've ran a code check on it this evening after checking the fuse first and I'm getting the follow,
Code 01273 Fresh air blower (V2) sporadic 003 - Mechanical failure.
Any ideas people ? :?
Thanks for that, I've just been out with my torch playing with the fuses just in case but no luck. I'll have a play with the fan tomorrow, weather permitting. :wink:
1K2820015
Ok, had the glove box out this morning and then the fan. It was a bit stiff and had some debris inside, leaves and stuff so I've cleaned it out and given it a spray with WD40. So far so good. If it happens again I'll get a new one.
Thanks for your help. Saved me an expensive trip to the garage. :roll:
Mine packed up a year ago.
Audi wanted it in for diagnosis but had to wait for a couple of weeks. Took it to my local inde, who pulled the fan out and lubed it. Less than an hour - ÂŁ40. He reckoned it was a common issue and easily fixed (as you did), but Audi would have fitted a new blower motor for about ÂŁ400...
Worked fine until I sold the car last month.
Peaty poor really. Mine has only done 39k. I would have expected better form Audi thb.
Damn poor.
Mine was a 12 plate with only 12k on it.
