Yet another wheel question, would the difference in tyre width be for 8J and 8.5J ?
Would they both be 235?
Its ok Gordon, its good to be me... :lol:gogs said:Ha ha, I wish I had half the knowledge you guys do!Garth said:Careful gogs, you're turning into Damien![]()
I need answers :-o. Aaaarrrggghhh
Not true but I know what you're saying. I'm in a similar position to Gordon at the moment and am probably guilty of planting the seed of using wider tyres on the rear. This is purely my preference on aesthetics but more rubber grip should theoretically enhance handling charateristics but we're splitting hairs here as were only talking about 10mm.roddy said:TBH, i cant understand why anyone would fit diff size tyres on same size rims,, it is going to cause different handling characteristics,,, if i had 8.5 i would go for 240 x 40,,, ( i think :? )
Gordon, I calculate if you use 15mm Adaptors both Fronts and Rears will be 6mm inside the arches based on 8" rims on the front and 8.5 on the rear. The calculator below is approx 5mm inaccurate so 1mm inside is actually more like 6mm.gogs said:I'm looking at 19" with ET32 but 5 x 112, from what I can work out I can't get an adaptor that will keep the fronts within the arch :-(
Am I correct in thinking this?
Kaz I know your a bit of a wheel guru ;-)
