Hoi hoi!
Ive just done my calipers. I know its not a hard job and done it to two minis previously in exactly the same way-except this time nothing seems to have gone to plan.
On Friday i used a wire brush drill end and cleaned up the rear, washed it down and removed all dust ext. waiting for it to dry, masked it up and painted it with hammerite red smooth left over from when i did the mini (2 years ago).
It looked horrid though and thought that if its a TT i want it to look good.
So i stripped it all back, bought some hammerite smooth red spray and masked it up again and sprayed. Then did the other back one. I did as the instrcutions stated and even waited between 20-25 mins between coats instead of 15.
On saturday i started and completed the front brakes in the same way.
The car has thus been sitting un moved since Friday to allow the paint to really set before putting the front brake retaining clips back on.
HOWEVER when doing this its scratched the paint which still seems quite soft on the front, ive checked the rears and although quite solid feeling if i press my nail into the paint it leaves an indent. One of the fronts has developed an ever slight wrinkle effect localiesed to where i just touched up the scratch.
Therefore my thinking is they are not dry all the way through. The paint is not too thick than i can tell - and even went on a lot more thinner than the paint version.
I took it for a quick spin, loads of hard braking to heat up the brakes and start drying it from the inside. will probably do it a few more times today.
QUESTIONS are...
1) any idea why it hasnt set hard yet or am i just being impatient?
2)is it a good idea/safe to keep taking it for short blasts and braking to heat up the calipers? (i have a long trip planned for wednesday and dont want this to effect braking - but also dont want to have to spend all day trying to strip congealed hammerite from all my calipers!
Any advice truly appreciated?
QUESTIONS are...
