As the TT`s alternator charges at around a 14.2 volts continuously when engine is running can I replace starter battery with an AGM type.
Thats the starting price, you then put the code in atbthe checkout. Comes in at 108.David C said:How are you getting ÂŁ108 ??Gixxer123 said:Just lookong at getting a new 096 agm bosch s5 battery for the 3.2, euros do one with the discount code for ÂŁ108 which I am happy with as they are only round the corner from me.
The Bosch "S5 A08" 096AGM is ÂŁ181 with the blackfriday discount. :?
I have been watching.my 3.2 is floats from 14.2 down as low as 13.3. I am trying the battery on mine first, as its only showing.11.1v.bobclive22 said:This alternator is for sale on Ebay, it is compatible with both the 180T and the 3.2 from years 1998 to 2004
AUDI TT 8N Alternator 1.8 3.2 98 to 05 Bosch 028903030 038903024G 028903028E
https://www.ebay.co.uk/itm/AUDI-TT-8N-A ... 2348154763
How can what appears to be a standard fixed output alternator give a continuous 14.2 volts in my 1.8T and yet give out between 14.2 and 13.5 volts in Imartyns 3.2.
I am trying to ascertain what the charging regime is for the 3.2 with an AGM battery, is it static around 14.2 volts or floating to 13.5, anybody.
The starting price is ÂŁ329.99 ...!!Gixxer123 said:Thats the starting price, you then put the code in atbthe checkout. Comes in at 108.David C said:How are you getting ÂŁ108 ??Gixxer123 said:Just lookong at getting a new 096 agm bosch s5 battery for the 3.2, euros do one with the discount code for ÂŁ108 which I am happy with as they are only round the corner from me.
Are you checking voltage with a meter pushed into the cig lighter socket, see link below, as it appears 11.1 volts may indicate little or no charge going into the battery and 13.3 volts when car is running indicates only a trickle charge coming from the alternator which probably won`t keep the battery charged in normal running.I have been watching.my 3.2 is floats from 14.2 down as low as 13.3. I am trying the battery on mine first, as its only showing.11.1v.
Handy to know the alternator is the same though, thanks
The S5 008 096 (not AGM) is ÂŁ108 after the blackfriday discount.Gixxer123 said:David c, I will check what euros is giving me in the morning when I pick it up, if it ends up being ÂŁ181 then I suppose I havnt any choice. Thanks for pointing us in the right direction.
There isn'tbobclive22 said:Gixxer123,
Hi,
When you change battery could you check whether there is a sensor on the negative battery post,
Thanks, Rob.
Should get a steady 14.1/2 volts then.There isn't
