101 - 120 of 179 Posts
base86 said:
LeighK said:
not sure I understand correctly where to find the hardware version,
From the engineering menu I have Current Version:MHI2_ER_AU43x_P3626 and MU Software 0892.
Its a 2017 car.
You can update that to P5098
But now I am steeling someone thread here. Maybe a central download/firmware topic is a better way indeed?
I got it to p5098 with no problems but still when I try to update the VC I still see the update option greyed out and FPK [N] ?
LeighK said:
Its a 2017 car.
From which version to version you are trying to update?
I got it to p5098 with no problems but still when I try to update the VC I still see the update option greyed out and FPK [N] ?[/quote]
From which version to version you are trying to update?[/quote]
Trying to get to 296 from the link on here , not sure what current version is or where to find it in the engineering menu, thanks
Can someone far smarter make a new thread and write down:
1. Update procedure
2. Upload all the VC updates that we can find between us. And then write down the max update version for each hardware and unit versions?
I see a lot of us are asking the same things over and over. So this will help not to clutter or repeat ourselves. :)
Tebor123 said:
pcbbc posted an excellent tutorial on how to access the Engineering menu. Perhaps that should form the basis of any new thread. No point in reinventing the wheel!
The thread is here - https://www.ttforum.co.uk/forum/viewtopic.php?f=98&t=1727210
Sure, as far as the instructions are concerned.
But we also need categorisation of update files.
For example h30-32 etc etc 2015-2017 max update is 290 (for example).
Hello,
I would also need this to get the Audi Smartphone menu item.
After updating the MMI to P5098 the phone functionality hangs sometimes and I can only fix it by turning off/on the BT on the iPhone.
base86 said:
LeighK said:
do you think I could get a copy of 265 VC please?
Sure will try to put it online somewhere?
andreic said:
Hello,
Which version of the VC are you running?
Hi friends,
I Add red zone in the revs counter on my Audi TT 2015/2016... It was working
However, I retrofitted the CarPlay / AndroidAuto and updated the 5F module (to work the icons), after that the coding doesn't work anymore,
StartUp logo TTs works but RedZone no longer works.
Does anyone know how to activate the redzone in this new firmware?
my fw ver:
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 A HW: 8S0 920 790 A
Component: FBenRDW H35 0296
Coding: 042D0140288000081A01E8C09000800000000000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_DashBoardBOSCHAU33X 001023
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 377D9DDE8E4D82FCE9-8062
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8S0 035 045 M HW: 8S0 035 045
Component: MU-H-N-RW 043 1339
Serial number: A583J0FB004327
Coding: 01330403FF08000011220001001A00002F0000E0007000007E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
VCID: 39799BE6B859948C1F-806C
Data medium:
Subsystem 1 - Part No SW: V03 959 801 FN HW: -----------
Component: ROW 2016 --- 0055
Serial number: --------------------
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 L
Component: ControlUnit_H H22 0206
Serial number: C1000015091500010077
Compact Disc Database:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 4007
No fault code found.
rafamonteiroo said:
Hi friends,
my fw ver:
Data medium:
The reason Redzone disappear for your case is because upgarding VC firmware to 296. Audi block it.
Luckily you will get a working G-meter instead for VC with 296.
Mokorx said:
rafamonteiroo said:
Hi friends,
my fw ver:
Data medium:
Thank you for the explanation,
I liked RedZone, it's sad
well, now I'm going to activate the G-meter ..
