Audi Smartphone Interface icon missing on VC
52K views 178 replies 45 participants last post by  Heath2015
Hi to all,
can You help me ?
In my TT 2015 I have uploaded software ver1339 to MIB2
I have activated carplay, but the „Audi Smartphone Interface" icon is missing on VC :-(
The workshop that uploaded it to me did not solve this problem
Carplay works ok but i have problem running it
After connecting the cable to the iphone, carplay starts, but if I switch to another menu in VC,
I can't go back to carplay, because there is no icon ASI in the menu.
I have to reconnect the cable or enter via SIRI
Do you know how to run the ASI on VC icon?
I have OBD 11
thank you for any help
#27 ·
Hi! I also got AA activated in my 2015 TTS, but it's not working properly in VC. My Android10 phone shows that AA is working and connected, also the VC setup connection manager shows my phone connected as AA phone, but nothing shows in my VC screen. No icon in menu, no AA menu/apps. Bummer!
#28 ·
Have you done this mod in the adaptions of 5f?
IDE03471-ENG138662-Configuration du véhicule-Mirror_link => ON
IDE03471-ENG130248-Configuration du véhicule-Google_GAL => ON
IDE03471-ENG130249-Configuration du véhicule-Apple_DIO => ON
IDE03471-ENG138663-Configuration du véhicule-Smartphone_interface_for_rhmi => activé
#29 ·
qenq said:
No, I didn't get it. I can't start with this update.
The car sees this update, but with every update option is N/A
Option START UPDATE is gray
What about Google earth? After this update and the activation of Carplay my Google earth is gone away...no way to see Google maps (on original maps obviosuly)
And you??
Jacopo
#30 ·
Yes, those are done like that in the adaptions of 5f.
#31 ·
strange, however google earth is going to disappear on all pre-FL models on 31/12/2020... so you just anticipated its death.. :cry:
And you??
Jacopo
#32 ·
My problem with the CARPLAY icon has been solved by replacing Unit 17
Look at the pictures I had a test version of the Unit 17 !??
How could this be ?
That was the reason why a new version sw could not be uploaded
#35 ·
Is it possible your car is an early show pony/press car? Granted that piece of hardware shouldn't be in the car but that's all I can think of.
#36 ·
If his car is from 2014 its possible. Wasn't 2014 the "debut year"?
If so they Audi should be the one to pay for the replacement
#37 ·
Those stickers were used for units with pre-release software but the sticker on the other side shows it was flashed with production software and the date/version used. unit is fine, there was no hardware difference.
#38 ·
How could this be ?
If you don't mind me asking, how much did you pay for the new unit 17?
#40 ·
Jacopo79 said:
If you would buy a unit 17 from a TTs or a TT competition maybe you would gain the central rev dial...
I own a TTS model and loving the central rev dial.
Features that I want are
- Sport display (g-meter/active TPMS) because I have a PFL I can't activate it with VCDS
- Smartphone interface
Would be nice though to get an RS VC with the flashing rev counter.
#41 ·
How could this be ?
I have paid 200 euro for Unit 17 and 220 euro for coding this unit
Unit 17 is second hand from My19 with letter D
#42 ·
qenq said:
How could this be ?
I've have read some stories that you can't program the VC if it has ran more then 500 km or miles. Did you manage to buy one with lower milage or was it programable?
For that prices I am very interested. Can you point me to your seller?
#43 ·
I have a pre-FL TTS mee too, and the G-meter works perfectly... and active TPMS can be retrofitted easily
- Sport display (g-meter/active TPMS) because I have a PFL I can't activate it with VCDS- Smartphone interface
#45 ·
The active TPMS is retrofitted and working fine. Only "problem" I have is that the "sportsdisplay" (not the sport layout which is standard on TTS) is not visable/selectable via the VC. Tried every coding with VCDS but it will not show.
Maby it is just a firmware thing, will try the dealer if they can flash it.
But if it is that cheap, I am interested in a RS cluster for the flashing rev dial :lol:
#47 ·
it's the power and torque dials, you get an extra option called sports display on the RS.
#48 ·
kevin#34 said:
cannot understand exactly what you call the "sportdisplay"
(when I am on the sport layout, G-meter is on the right part of the VC, as for TPMS or torque/power gauges)
To set or change to that mode you can select "sport display" on the left (LHD) menu. In my own topic I've uploaded a photo where that feature is missing.
I guess when you go to the car menu, select the left option button (so you can toggle between all the car features) there should be text called "sport display". Since the default view for you is the G-Meter within the sport layout I guess you never had the need to look for it. If you switch to, lets say, the assistance view or the short/long range statistics with the sport layout enabled and then you want to re-enable the g-meter you have to select the sport display feature within the car menu.
Sorry for the blurry explanation but since I don't have the menu option I can't show you a picture of it.
@Toshiba you seems to know the feature I'm talking about, can you upload a picture of it?
#49 ·
when I am in the sport layout mode (big tacho in center), I have G-meter on the right side and I can shift from lane assistant to short/long range statistics on the left side of the VC; in this condition the G-meter is still present on the right side, I don't have to re-enable it, if this can help
base86 said:
EDIT
#50 ·
Can you change the G-Meter for lets say the date and time?
I think that is done via the "additional display" feature. That one I do have, wondering now if you have the G-Meter there in the same list as the date/time milage etc.
