Hi - Hope this helps....I did this for my Golf Mk5 and used Vagcom to bleed brakes.
Link for info
http://www.andrewhope.co.uk/automotive/ ... epair.html
I found a few write ups and made the best of them all.
What I did was get a cheap GUNSONS EEZIBLEED EASYBLEED kit and 1/2 filled it with clean brake fluid and connected to mater cylinder and laid it on it's side above the master cyl so that as fluid was pumped out the bleed nipples the master cyl was automatically filled.
Now to vagcom and bleed nipples. Again I bought some brake bleed tube from ebay like
http://www.ebay.co.uk/itm/Quality-Car-A ... SwwbdWG-CC but I made it longer using clear silicon tube so you can see bubbles if you need to.
I then opened front 2 bleed nipples with silicon pipe connected and each ending in a glass jar to catch the brake fliud.
Then do the vacom bit ....found a copy of a post by someone (sorry don't have link but this is what I used) so thanks to the guy who wrote it:
For future update
tools & stuff you need
brake fluid (3L)
2 x 11mm spanners
2 x bleed tubes with one way valves on
2 x receptacle at least 1L in capacity
first you need access to the front bleed nipples, i jacked up the front, placed on axle stands and removed both
wheels.
then put the spanner, bleed tube and receptacle on each side.
open the brake fluid resevoir and have your fluid ready to keep the resevoir topped up at all times. i got a
friend to do this to speed things up, it's probably possible on your own but will take a while longer.
goto ABS, basic settings blah blah whatever it is and click from 000 up to 001 and then you get a MSG on the
screen saying "PRESS AND HOLD PEDAL" or words to that effect. whilst doing this the ABS pump is activated
and the pedal can be felt kicking back
(002) it stops pumping and your told to relase the pedal and open the front 2 bleed nipples, then you need to
click to continue
(003) it will tell you to wait for 10 secs whilst the ABS pump is activated and fluid is pumped out of the now
open bleed nipples
(004) it tells you to pump the pedal 10 times and then close the bleed nipples, then you need to click to
continue
(005) "PRESS AND HOLD BRAKE PEDAL" untill told to stop
(006) it stops pumping and your told to relase the pedal and open the front 2 bleed nipples, then you need to
click to continue
(007) it will tell you to wait for 10 secs whilst the ABS pump is activated and fluid is pumped out of the now
open bleed nipples
(008) it tells you to pump the pedal 10 times and then close the bleed nipples, then you need to click to
continue
(009) "PRESS AND HOLD BRAKE PEDAL" untill told to stop
(010) it stops pumping and your told to relase the pedal and open the front 2 bleed nipples, then you need to
click to continue
(011) it will tell you to wait for 10 secs whilst the ABS pump is activated and fluid is pumped out of the now
open bleed nipples
(012) it tells you to pump the pedal 10 times and then close the bleed nipples, then you need to click to
continue
(013) "PRESS AND HOLD BRAKE PEDAL" untill told to stop
(014) it stops pumping and your told to relase the pedal and open the front 2 bleed nipples, then you need to
click to continue
(015) it will tell you to wait for 10 secs whilst the ABS pump is activated and fluid is pumped out of the now
open bleed nipples
(016) it tells you to pump the pedal 10 times and then close the bleed nipples, then you need to click to
continue
(017) ABS BLEED PROCESS COMPLETE!
once your done approx one litre of fluid will have been expelled from each caliper
points to note, i did not go full travel on the pedal every time, i probably only used about 75% of the pedal
travel and i pumped the pedal slowly to prevent damaging the master cylinder seal which everyone is always
banging on about.
so from the above you can see it's 4 complete cycles, not 17 cycles as someone suggested but 17 is the
number you'll see on the left at the end when it says it's completed
losvre is offline
Back to my bit.
So I did the above but I must say I did not do it 17 times....I think I did maybe half that and after each vagcom pump...before I did it again I shut bleed nipples and topped up bottle with brake fluid.
I bought 3 litres and it took just over 2 to do the lot. I did front 2 first at same time. then back 2.
Worked for me but I agree it takes a bit of planning.
Hope this helps.
