Hi All,
So i'm a bit panicing right now. Last night someone tried to update my old "letterless" VC to 295.
That failed a couple of times with errors 130 and 227.
After several failed attemps he asked me to pull the negive plug of the battery for 5 minutes. After that, the car won't come back on contact any more or start.
As soon as you put the negative back on the battery VC boots up, kind of, with a whole black screen and bright meters not showing anything
After a whole night without the negative I did managed to get it responding some kind, and was stuck on the empty screen with the "tiles" , afther that I was able to get in to the engineering menu and tried starting the update of 224 (on his advice)
That also failed and after that again no response from VC
Now, the main questions that I have
- Does anybody think I can "downgrade" or cancel the update so it will run again back to normal?
- If I call the dealer and let them order a new VC will that work and my car will run again? (I know it will costs me a LOT of money)
Thanks for your advice
