21 - 40 of 2,673 Posts
Discussion starter · #21 ·
-Enable auto handbrake when shift in P (my cable can't have access at this unit, so not tested)
Unit 53
Security access, code 78713
Adaption
Find "shift p to epb"
Activate it and done.
-Release automatically parking brake without seat belt (my cable can't have access at this unit, so not tested)
Unit 53
Adaption, find the function and activate it
-I hope soon, activate high beam assist
-dynamic front indicators, I need your help to research...check in the unit 9 if you have all parameters activated like mine:
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken, active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken, active
(3)-Dyn. turn signal modes-ZV_Blinken_zu, active
(4)-Dyn. turn signal modes-ZV_Blinken_auf, active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken, active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung, active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken, active
(8)-Dyn. turn signal modes-Taxi alarm flashing, active
(9)-Dyn. turn signal modes-Panic flashing, active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken, not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2, not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts, active
(13)-Dyn. turn signal modes-Richtungs_blinken_links, active
(14)-Dyn. turn signal modes-ABBA_Blinken, active
(15)-Dyn. turn signal modes-Crash flashing, not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN, active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS, active
(18)-Dyn. turn signal modes-Emergency_alert_blinken, not active
JiffyTT said:
ManuTT said:
Good! You're not the only one who's asking for these led!!
Just got my RossTech sent me me. I will try the dynamic indicators in a couple of hours. Manu, is there anything I need to know before I start attempting this?
You have to scan everything and save original log file so you can undo if something goes wrong.
You also need to check in Installed Tab (in Vagcom software), note down what module you have on your car, i.e : 01-Engine, 08-Auto HVAC, 17-Instruments etc... Note down the first 2 characters of each module (01, 08, 2B etc...)
Then go back to main Menu >> go to Application >> Controller Channel Map.
Inside that, put in Module number as above (first 2 characters), tick the box Measuring Value, Adaptations in Function, and on Output, select CSV file. Then click Go, it then scans that module and prompt you to save the file somewhere on your laptop.
When the module scan finished, input the number for other modules and scan every single of them and save all to separate CSV files until completing all modules your car has.
Then you can start to play something.
Some modules will take a long time to scan so make sure you monitor the battery level.
JiffyTT said:
Thanks very much! Will follow your instructions. I actually tried to change a value for rear drl's to come available on the ni. But it said that I needed a security code?
Yes some modules need security code, some not.
Before go to the Adaptation to change anything on a Module, you need to go to Security Access first, then while in there, just click the mouse in the security box and wait a couple of seconds. If the module has access code then it should appear in the yellow box the number and you can type in that number and hit do it. And go back to Adaptations to change things.
If nothing appears after a couple of seconds then that module does not required a code for Adaptations.
Remember that if the module needs the code but you dont put in and go directly to Adaptation to change value then it wont work.
So best practice is to go the Security Access to enter the code first before changing things in Adaptations.
Alternatively you can go to Security access of every module and note down the code of every one of them, and which one does not require the code so you can access quicker next time.
Thanks very very much. I can't seem to find the security screen just yet. But I'm backing up the modules into logs. Can you provide a screenshot?
Thanks in advance.
I have also checked Manu's coding for dynamic indicators. It looks like I run the same codes, but no good. My LED headlights don't seem to do the sweep.
Discussion starter · #35 ·
New possible things found:
-change the speed when high beam assist turns on full beam (I lowered it a bit)
-change the sensibility of the camera to turn on and off high beam
-lane assist, change the gong sound when you don't have hands on the steering wheel
-lane assist, change the vibration soft medium strong
-lane assist, change how much help from the car during a bend soft medium strong
I need to decrease the speed to turn on lane assist and to keep it active more time without hand but I didn't find them yet!
Discussion starter · #39 ·
-adjust the full beam on speed
Unit A5, permission code 20103, adaption, activation speed... change the speed and do it.
I set to 30 km/h so as soon as is dark (so out of the city) the light is with me!
Discussion starter · #40 ·
tried everything bet nothing for the dynamic indicators..there are some hidden parameters that is impossible to know how they do..and you understand I can't change these parameters...it's like some function in the TTs (lap timer, sport mode in the VC) they don't have parameter to change but are there because the unit is the same!
