There were some battery issues when I picked up the car, used a jump pack to start it and the dash was flickering, the rev counter and speedo weren't working either.
All settled down after a few miles of driving. The car charged the battery on the way home and it started the morning after.
Put it on charge to be sure and it then wouldn't crank the engine after 5 hours on charge.
Removed the battery and charged over night. It gave 12.77 volts, back on car and checked for parasitic drain, seemed ok at 300ma.
Still wouldn't crank engine over so got new battery.
I hadn't noticed before but both radiator fans are coming on full with ignition on and stay that way until the car is warm.
Do I need to look at the coolant sensor and fan controller?
The flickering is still happening and the speedo and rev counter at 0 until 10 mins of driving. With headlights on all instruments/radio and switches flash except the heater module (presume different circuit)
https://drive.google.com/file/d/19RTxxE ... qwJC3/view
VCDS lite threw up the following codes
https://drive.google.com/file/d/19aF7Qx ... fwkYt/view
Top code led to a perished vacuum pipe
Not sure about the middle 2 and last one is ECU relay. Tried to have a look at that between rain showers but strut brace seems to be stopping relay box cover from coming off.
Thanks in advance for help and suggestions
