Thought I'd update this post with the information from the Audi A3-Quattro.de website here in Germany. Seems they're running into problems with their website so Michael Lorch was kind enough to email me all the information which I have posted here for safe keeping. To avoid any confusion with the product names, additives from Ruf Lambda and Addinol Lambda is now BeDi. Products known under Lambda Germany will in future be sold under the brand name BeDi.
The Addinol website can be found here -
ADDINOL - manufacturer of lubricants from Leuna. We develop high-performance products: Automotive ✔ Industrial lubricants ✔
addinol.de
The Addinol shop can be found here. Note, this website is in German, but if you right-mouse click you can select "Translate to English" -
Additive von Addinol und Ruf Lambda Bedi
The original post can be found here (in German) if you can access the website -
http://www.a3quattro.de/index.php?page=Thread&threadID=14163
The Lambda products can be used with petrol and diesel. Availability may be limited depending on your location.
Lambda Tank Otto 500 ml
Lambda Tank Diesel 500 ml / 750 ml
Lambda Oil Primer 250 ml / 500 ml
Lambda Oil Primer EXTRA 250 ml
How do I use Lambda products?
Lambda Tank Otto for petrol vehicles
To prevent deposits and/or clean light deposits, it is sufficient to add 1 can of 500ml to a full tank of petrol.
Repeat at every service (every 10-15000km)
Normal driving is completely sufficient
In case of problems or deposits, add 1 can of 500ml to half a tank of petrol.
For normal driving, you should also accelerate from time to time and drive a little harder or take motorway trips. Run the tank down to a quarter and then refuel.
Lambda Tank Diesel for diesel vehicles
To prevent deposits and/or clean light deposits, it is sufficient to add 1 can of 500ml to a full tank of diesel.
In case of problems or deposits, add 1 can of 500ml or 750ml to half a tank of diesel.
Lambda Oil Primer
It is used to clean the oil circuit as part of the oil change service.
It is added to the engine oil.
Engines with an oil volume of up to 5 litres: 250 ml can
Engines with an oil volume of more than 5 litres: 500 ml can
For VW/Audi engines with 1.8 or 2-litre displacement, the 500 ml can should also be used.
Make sure that everything is done in quick succession.
Check the oil level before filling.
Before filling the Oil Primer, drain or siphon off 500 ml of used oil.
If you are using the 250 ml can instead of the 500 ml can, use only 250 ml.
Allow the engine to run for approx. 3-5 minutes when stationary to ensure good mixing.
Then drive the engine for approx. 30 to a maximum of 50 kilometres.
Warm up the engine. Afterwards, you should avoid driving at a constant engine speed or constant speed. Cleaning is not as effective here.
In order to clean all parts properly, alternating load conditions should be used.
Frequent acceleration, sometimes higher engine speeds, motorway driving.
Many parts in the engine, such as camshaft phasers, chain tensioners and oil valves, live from movement. They can only be cleaned efficiently if they are moved correctly.
In the case of camshaft phasers, it is important that they utilise all the adjustment travel.
After driving, the engine oil must be drained IMMEDIATELY !!!
It must not be allowed to cool down. The engine oil must not be drained at a later date.
Allow to drain well (approx. 10-15 minutes)
The Oil Primer EXTRA is used to clean dirt during operation that could not be removed by the normal Oil Primer.
It can often happen that the cleaning journey of up to 50 km is too short and is not sufficient to remove all stubborn dirt.
The Oil Primer EXTRA gently dissolves the dirt already dissolved by the Oil Primer and returns it to the oil filter.
It is not a cleaner in the conventional sense, but has lubricating components.
Add 250 ml Oil Primer EXTRA to the oil circuit. Start the engine and let it run for approx. 3 minutes while stationary.
Then IMMEDIATELY drive AT LEAST 10 km to mix the oil!!!
This must be strictly adhered to.
The Oil Primer EXTRA may only be added to fresh oil. NOT in oil that has been in the engine for a long time !!!
Duration: It is recommended not to drive more than 5000-7500km with it.
Afterwards, when the kilometres are reached, you should flush the oil with Lambda Oil Primer to rinse all residues of Oil Primer EXTRA and dissolved substances out of the engine. Then use fresh oil with a new filter.
The oil level should be adjusted so that the 250 ml of Oil Primer EXTRA reaches the filling quantity specified by the manufacturer.
The safety data sheets, product literature (German) and 2024 Product Catalog are attached -
